water leaking under dashboard
Discussion in '1st Gen. Tacomas (1995-2004)' started by mattgray44, Oct 1, 2008.
  1. Oct 1, 2008 at 7:14 PM
    mattgray44
    mattgray44 [OP] New Member
    america
    04 tacoma
    Has anybody had a problem where when you make a sharp left or right turn you hear a sliding sound under the dashboard and then water starts dripping from under the dashboard.:mad:
  2. Oct 1, 2008 at 7:18 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    I've never experienced that.:confused: Welcome to TW, somebody here might know.
  3. Oct 1, 2008 at 7:20 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    Its probably your heater core bud. You will have to pull all that stuff out from under your dash to see if its a hose or if the core need be replaced. If I were you I would replace the core either way. Its a pain to get too.
  4. Oct 1, 2008 at 7:31 PM
    swatjoe592
    swatjoe592 Beware the Puma...
    Southeast Texas
    05 Tacoma PreRunner
    20" gangsta wheels, baby seat
    I had a windshield replaced and it wasn't sealed right. Water accumulated behind the dash and would leak onto the floorpan. Check you glass for cracks or leaks. Hope this helps!
  5. Oct 2, 2008 at 8:51 AM
    crazydaze_95
    crazydaze_95 Well-Known Member
    ne md
    mall crawler till the jeep dies
    6inch fabtech lift kit, 35inch mickey thomphson atz, 16inch pro comp rims, deck plate mod, k&n air filter, diff lock grey wire mod, b&m trans cooler, flowmaster 40 muffler, clarion dxz755mc head unit, pioneer 6x8 3 ways in all four doors, infinity basslink powered subwoofer, mesh grille, power moonroof, geared to 4.88, fabtech light bar, custom skid plate.
    My nissian did the same thing, its your air conditioning condinsation. The line that normally drips under your truck is clogged up.find the line and blow into it and it will unclog.On my 04 tacoma it is located on engine side of firewall on the passenger side down near the header.its a 90degree bend peice of pipe that has end cut off.
  6. Oct 2, 2008 at 9:07 AM
    tacomaridesbikes
    tacomaridesbikes Member
    william
    kinston, nc
    05 4x4 sr5
    9in fabtech lift, 4.88 gears, Snorkel, 37in BOGGERS, 17in MT classic locks, ARB bull bar with 9.5 milemarker, All-Pro Rear Bumper, flowmaster dual exaust, K&N cold air intake, airraid throttle body spacer, sirus radio, cobra cb with PA system, and alot of strobes
    mine has dripped on my feet
  7. Jul 12, 2010 at 11:06 AM
    gentile610
    gentile610 New Member
    This problem has just began for me. If I make a sharp left, I hear the water underneath the dash and it pours on my passanger side floor. When I make a sharp right, it pours directly on my right foot. It happens everytime. Have any of you been able to correct the problem and how?
  8. Jul 12, 2010 at 11:23 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    well the other night i was driving barefoot and i had water dripping on my gas pedal foot every 20 or so sec.s
    i went under there yesterday and found the 2 ac lines were un insulated and it was real humid out and they had condensation dripping off them hope that helps
  9. Jul 12, 2010 at 12:55 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I wouldn't think its a heater core on a 04, check the A/C drain hose on the firewall, look under the dash on the passenger side you can see where the hose exits the cab, mine has no hose just a metal eblow, I slide a thin 8 inch nylon zip tie into the elbow to see if it was blocked.
  10. Jul 22, 2010 at 4:53 PM
    DigB
    DigB Go Jets GO!!!!!!
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    Try the small drain tube on the passenger side of the of the truck that goes through the firewall, probably plugged. Mine is doing the same thing right now and the best that everyone has come up with is the plugged tube. You can pull it out and blow out the dirt, thats the best that I've found so far, hope it helps.
  11. Jul 24, 2010 at 11:01 AM
    scottymc
    scottymc Member
    Whiteford MD
    02 double cab trd
    none yet
    Mine was doing same thing so I checked the tube coming out the fire wall. The tube was turned upside down so I simply turned it so it was facing the ground and water started trickling out immediately.
  12. Jul 24, 2010 at 6:23 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    Yup there you go. Was going to say plugged water hose coming from the AC unit. It's a fairly common problem i all cars when the hose gets plugged.
