-   -   2 quick questions (http://www.tacomaworld.com/forum/1st-gen-tacomas/156201-2-quick-questions.html)
tsab916 05-10-2011 02:24 AM
2 quick questions
How do you guys mount your shocks?
-with the shaft pointing up or down?
- I have mines pointing down because I figure most dirt, dust and water would fall off and hopfully not scratch the shaft.
What size rims?
- do you guys buy same size rims that originaly came with your truck from factory?
-im looking into some rims right now and can't figure out if I should go with 15" or 16" is there any benefits in getting 15s over 16s or visa versa...my oem rims are 16" so should I stay with that size or it doesn't matter.
- sorry 3 queston now... should I go with steel rims or aluminum? And why?
1998tacoma4x4 05-10-2011 01:55 PM
I mounted mine with the shaft up/boot down. I was unsure of this too so i PM'ed wheelers and they told me to mount them that way.
I have 15" rims on my truck from the factory, but i just replaced them with 15" Mickey Thompson classic II's in black.
Enigmaaron 05-10-2011 02:13 PM
Originally Posted by tsab916 (Post 3152523)
What size rims?
You can get either size. 15" rims (and tires) tend to be cheaper as well as having a wider selection. Of course if you change rim size you have to buy all new tires at the same time which can get pricey. Figure out what you want to get, then look at the price difference between the two sizes and see if it's worth it to you.
Steel = cheaper, heavier and will bend some before braking if you take a hard hit so you can still hold air in the tire and get somewhere to get it fixed, succeptable to rusting if the paint isn't kept up
Alloy = more expensive, lighter and will brake/crack and lose air if you take a hard hit, will not rust so if you're in a snowy climate (and lazy like me) may be a better choice
