bumming with misfire
Discussion in '1st Gen. Tacomas (1995-2004)' started by gofas, May 19, 2011.
  1. May 19, 2011 at 8:05 PM
    gofas
    gofas [OP] Well-Known Member
    Russell
    Ukiah
    4x4 Timberland Mica Access
    ImMrYo review mirror bracket.
    well darkness is upon me and I'm beat from work so back to net surfing and reading on this issue.
    (Re-cap of today's misfire)I was cruising down the freeway and in an instance bad stumble with flashing code light. Lucky I was at my exit. And then went on to my own troubleshooting and even burrowed a code reader this evening.
    I'm sick, feel like puking that I'm still dealing with problem truck and wavering trust with this mechanic.
  2. May 22, 2011 at 6:42 AM
    gofas
    Russell
    Ukiah
    I'm always thinking the worse! I need to chill out. two of my plug wires were touching near power steering reservoir that created horrid misfire. Make sure you route plugs properly and do not let them touch each other. Along with that buy Toyota plug wires which come with nice harnesses ready to install.
