Help with 3.4L Spark Plug Gap
Discussion in '1st Gen. Tacomas (1995-2004)' started by cclax2145, Oct 21, 2008.
  1. Oct 21, 2008 at 3:20 PM
    cclax2145
    cclax2145 [OP] Well-Known Member
    Houston
    2002 prerunner SR5 Blacked out
    Deckplate mod, K&N drop in, blacked out tails and emblems, 3 inch toytec spacer/AAL lift, Alpine head unit, Boston acustics speakers, and 10 inch image dynamics sub (in custom seat/box), Alpine EQ, Flowmaster 40 series, and viper alarm system, 33inch bfg MTs, 15inch black steelys
    Does anyone know what gap i need to set my plugs to. The guy i talked to said it was 35 but he didnt even ask what engine size so im just wondering if he was right or wrong. I got a 3.4L v6. Thanks
  2. Oct 21, 2008 at 3:25 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i think i set mine to right about 40 or so........no problems here.
  3. Oct 21, 2008 at 3:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    40 is the winner! :D
  4. Oct 21, 2008 at 6:34 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    .44 is the gap. If you buy them from the dealer or at sparkplugs.com they are pre-gapped.
    FirstTimeFirstGen likes this.
  5. Oct 21, 2008 at 8:37 PM
    bajaracer
    bajaracer Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    If they are dual electrode then they dont need to be gapped.
  6. Oct 21, 2008 at 9:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats what alot of people think, but they DO need to be gapped. The last dual electrode plugs I changed, the gap was WAY off. Its easy to re gap. Anyone who thinks that their plugs are "pre gapped" check them to be sure. Yes, 44 is the book value, but as the gap seems to grow larger over time, I have always just gapped @ 40 to 42. :)
    Captain Magma and Brie like this.
  7. Oct 22, 2008 at 5:40 PM
    bajaracer
    Charly
    Chandler
    Darn, i just replaced them thinking they were gaped. Time to redo them!!!
  8. Oct 22, 2008 at 6:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    most spark plugs are supposedly gapped, but everyone i have seen needed to be gapped a bit more.
  9. Apr 1, 2017 at 9:47 PM
    wilhed
    wilhed New Member
    wilhed
    Seattle, Washington
    black sand pearl '03 Tacoma manual 4x4 V6 Dohc 54z
    Fog lights; iridium spark plugs; otherwise all stock.
    You all are referring to millimeters I presume?
  10. Apr 1, 2017 at 9:53 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    .040"
  11. Apr 2, 2017 at 6:10 AM
    benrpd
    benrpd Well-Known Member
    Ben
    2003 Tacoma Xtra Cab
    None
    Holy crap, this is almost the length of a plug! Lol
    snowboard704 likes this.
  12. Apr 2, 2017 at 4:59 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    John
    Orange Texas
    2000 TRD
    OME and worth every penny.
    1.1 mm if you have a metric feeler gauge.:)
  13. Apr 2, 2017 at 5:12 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    .043 is what happens I used
  14. Apr 25, 2017 at 7:49 AM
    STEVEO13016
    STEVEO13016 Well-Known Member
    STEVEO
    2000 Tacoma Prerunner V6 2WD
    5100 Billy's set at 0" with 881 coils
    Anyone have suggestions on what brand is the best to use for tacos ?
  15. Apr 25, 2017 at 7:52 AM
    Burnett
    Burnett Well-Known Member
    Nolan
    North Georgia
    98' Xtra cab v6 4x4 evergreen pearl
    Bilsteins 5100's & 5125's, OME Dakar leafs Custom toolbox Custom bedstep/towhook/reverse light combo Custom Bedrack
    NGK or denso copper plugs change every 30k miles
  16. Apr 25, 2017 at 8:00 AM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    NGK BKR5EKB-11 is a stock replacement as is Denso K16TR11. It is highly advised you use these and only these. Never use a single electrode plug, never use a Bosch pos.
    As for the spark plug gap argument, they are factory gapped .44. That's what the non supercharged 5VZFE requires. If you're measuring the gap and you put a feeler gauge directly across the electrode and the arm then you are measuring from the corners on a concave surface and getting an inaccurate measurement. The measurement should be taken on the curve so to speak.
    If you choose to adjust the gap, which I've never had to do, make sure not to pry on the electrode, the part protruding in the center, or it can crack an destroy the plug.
    TacomaJunkie8691 likes this.
  17. Jul 18, 2017 at 10:20 AM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    bringing back an old thread...
    I just got a set of NGK BKR5EKB-11 from rockauto. All the plugs came with a gap of .020-.030 so I was starting to think I got the wrong plugs since the gap was way off.
    Anyone know how to gap these things without breaking the center electrode? All I have is one of those disc shaped gap checkers.
  18. Jul 18, 2017 at 12:59 PM
    dgshelto
    dgshelto Well-Known Member
    David
    San Diego
    1999 Tacoma TRD 4x4
    .040" all the way!
  19. Jul 18, 2017 at 12:59 PM
    dgshelto
    David
    San Diego
    1999 Tacoma TRD 4x4
  20. Jul 19, 2017 at 1:48 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Trapperr likes this.
