##### Tacoma overheating ####
Discussion in '1st Gen. Tacomas (1995-2004)' started by youngstah, Sep 24, 2011.
  1. Sep 24, 2011 at 8:44 PM
    youngstah
    youngstah [OP] Member
    I been trying to figure whats wrong and Im completely stuck. I have a 97 tacoma v6. It has a new radiator, new water pump, new thermostat, new fan clutch and a new timing belt. A new temp sensor too. I also did a leak down test on ech cylinder so its not the head gasket because it passed.
    I turn on the truck and it heats up to its pint. After 15 mins, it starts going up more than the normal temp. Its holding the whole pressure and there is no boiling in the radiator neither. If I turn on the heater, the temp gauge stays in the middle but as soon as i put it on D and take off, it starts going up.
    I also did a flush and also took off the thermostat and it did not overheat but the revs were pretty hicg. As soon as i put it on, the heat starts going up. I changed the thermostat 3 times already and one of them was a oem and still, same problem. What i notced is that theres is poor circulation but what can it be?
  2. Sep 24, 2011 at 8:46 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    maybe buildup of junk in the passages in the block? that is strange.
    did you mix different coolants when changing things out?
  3. Sep 24, 2011 at 8:54 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Is the temp needle going all the way to the H when you say overheating? Or is it just going above the halfway mark? Also what area of the country do you live in? What kind of climate? Sounds like you should have no probs with overheating with all you've done so far. Have you checked your fan clutch? It may be worn and not catching and cooling as it should when under load. Try turning the fan with the engine off, if it has some resistance it should be fine, but if it turns really easy, you may wanna change it.
  4. Sep 24, 2011 at 8:59 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Steve
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I know this sounds "unlikely" but one time I ran into a similar problem. It ended up being the Impeller on the waterpump was spinning on the shaft, and not really moving the coolant. It to was a new pump, just manufactured poorly (defective). Crazy right? it happens. Good luck.
  5. Sep 24, 2011 at 9:46 PM
    scocar
    scocar hypotenoper
    Do you have any weak collapsing hoses? Or did you change them, too?
  6. Sep 24, 2011 at 9:49 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    that's what she said
  7. Sep 24, 2011 at 10:41 PM
    scocar
    scocar hypotenoper
    I didn't see that coming. Cheeky monkey.
  8. Sep 25, 2011 at 3:50 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    possible defective parts? only thing i can think of is ur water pump if its having poor circulation. or you got junk clog up somewhere
  9. Sep 25, 2011 at 5:02 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Got the stat in the right direction?
  10. Sep 25, 2011 at 7:36 PM
    youngstah
    thanks for all your reply's. I think so too that is going to be a bad water pump.
