Please help! Bad vibration...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hoyt, Oct 30, 2011.
  1. Oct 30, 2011 at 3:16 PM
    Hoyt
    Hoyt [OP] Well-Known Member
    Green Cove Springs,FL
    03' SR5
    Fabtech Dirt Logic 6" OME 881 Springs Custom Leather Spidertrax Wheel Spacers Deaver Leaf Pack Light Racing UCA's Diff breather mod Scangauge II Doug Thorley Headers Magnaflow Exhaust TRD Supercharger AEM Intake Transmission Cooler ARE Topper Relentless Armour IPT Valve Body Smittybilt X2O 8000 w/ 12 Volt Guy incab controller URD 7th injector Kit AEM Water Methonal Injection Kit Devil Horns Smittybilt Air Compressor
    I have a bad vibration coming from somewhere and I can not figure it out. I have had the tires balanced several times and the alignment done three times and still cant figure it out. It almost feels like it is coming from the drive shafts but I am not sure. It is driving me crazy. I recently put a whole new suspension on the truck (see build) so it can't be that because its bad ass. Please somebody give me some ideals.
    Thanks...
  2. Oct 30, 2011 at 3:22 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Yep, I have to agree. Unfortunately your bad-ass lift is probably the cause of the driveline vibrations. Are they in the 30-40mph range?
  3. Oct 30, 2011 at 7:26 PM
    Hoyt
    03' SR5
    Usually it starts around 50-60mph range. This vibration is not normal. I have been in other trucks that dont have this. The lift is only 3.5" with Toytec coilovers, Light Racing UCA's, Fat Bob's Diff Drop, Deaver racing springs with Toytec shackles and 5100's around. It is driving me crazy. Feels like the whole truck is going to vibrate loose.
  4. Oct 30, 2011 at 8:12 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Try flipping your carrier bearing
    and/or getting a carrier bearing drop.
    Check your play in the u-joints also.
  5. Oct 30, 2011 at 8:18 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    another thing to check is on the 4WD the double cardan joint in the middle by the carrier bearing has a grease zurk for a total of 6 on the driveshaft itself. this helped mine a lot
  6. Oct 30, 2011 at 9:59 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If your coilovers are adjustable, take some lift out of it. 3.5" is more than IFS design can handle without creating problems with the CV joints and boots. I'll bet that you have worn grooves into the CV boots where the fins are rubbing against each other.
  7. Oct 31, 2011 at 11:11 AM
    Hoyt
    03' SR5
    Going with a carrier bearing drop, although can't really find one. So who makes the best one. I would rather have the bracket type verses the spacer type.
  8. Oct 31, 2011 at 11:14 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
  9. Oct 31, 2011 at 11:14 AM
    SCFirefighter
    Stephan
    Cary, NC
    I had Toytec ship me one with my lift kit. It's a spacer kit. They don't make it, but they stock it. Don't remember who made it.
  10. Oct 31, 2011 at 11:15 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Page 4 on Products.
    Brian makes the best one.
  11. Oct 31, 2011 at 11:22 AM
    SCFirefighter
    Stephan
    Cary, NC
    This one?
    That's a massive piece compared to my two little pieces of aluminum. :eek:
  12. Oct 31, 2011 at 3:03 PM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    Yeah thats it
  13. Oct 31, 2011 at 3:29 PM
    Hoyt
    03' SR5
    Ordered one today from Brian, it will be here this week. For a very novice mechanic will it be hard to install. Looks like just two bolts?
  14. Oct 31, 2011 at 3:33 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    i bet its ur support bearing! had the same vibration. move ur bearing up and down and see if the rubber in it moves alot. i replaced that, rides like a cadilac.
  15. Oct 31, 2011 at 4:19 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Brians carrier bearing drop is the shit. Very well built and completely eliminated all my vibes. You should be happy with it!
  16. Nov 2, 2011 at 5:47 PM
    96taco4x4
    96taco4x4 Active Member
    Austen
    Florida
    96 SAS Taco
    running into the same situation and cant figure it out, removed the rear drive shaft to try eliminating that, put in four wheel around the block and still had the same vibe, annoying as shit, hope you find an answer! possible wheel bearing, or bent rim?
  17. Nov 2, 2011 at 6:27 PM
    SCFirefighter
    Stephan
    Cary, NC
    Please post back in here if that bracket works for you OP.
  18. Nov 5, 2011 at 5:26 AM
    Hoyt
    03' SR5
    Installed Brian's carrier bearing drop although there still is a vibration even though it is reduced. Checked the support bearing it is tight. Looking for other suggestions. The vibration almost feels like the front tires are out of balance.
    I also had the CV axles and tirods redone.
  19. Nov 5, 2011 at 7:04 AM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    Did you try the "easy" on this???
    Rotate the tires and see if the "vibe" stays or transfers to your rear or even "seat"...
    Have you tried lowering the front ,even with "NEW'" parts, angles will give that small "hum vibe"...just enough to drive you CRAZY :confused:.
    In know you say the "Lift" is bad a$$ BUT did you have any "Vibes" before ???
    With all of these balances & alignments, is anyone looking at re-torquing bolts or "Shiney" metal surfaces ????
    Last "Idea", being a "Yota",everything on the lift was put in correctly??? driver side parts and passenger side parts were done correctly??? No shims or spacers went to an opposite side ????
    Sorry you have to keep "re-living" this and hopefully you find "it"...
    Good Luck...
    Old Man back quiet ...
  20. Nov 5, 2011 at 4:17 PM
    Hoyt
    03' SR5
    Had the tires checked again today and found out they were way out of balance. They balanced the tires but I am still not satisfied with the ride quality. So my next move is to wait for my Relentless Armour to get back from the powdercoater and get installed then the 4 wheel drive shop said they would look at adjusting the suspension to see whether it helps. They are also going to look at the ball joints and drive shafts. Stay tuned...
