Lift Questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by scalfee90, Nov 5, 2011.
  1. Nov 5, 2011 at 5:50 PM
    scalfee90
    scalfee90 [OP] Well-Known Member
    Shane
    Sylacauga, AL
    1999 Tacoma Manual 3.4L
    Custom skid plate, rock rails, front bumper & rear bumper, pioneer head unit with 3-way pioneer components, blinker mod, Eibach coils, Bilstein 5100s, Procomp AALs, American Racing Sawblades, M/Ts, BPV Bracket, deckplate, LED Dash
    I am about to run 33's, I'm going to buy some eibach 3" lift coils and bilstein 5100's. It says that with the bilsteins set at factory it will actually add 1 inch of lift for leveling? Is this correct? will i get 4 in the front or just 3?
  2. Nov 5, 2011 at 6:00 PM
    scalfee90
    Shane
    Sylacauga, AL
    well now that i figured that out, I'll run 3 inches on the back too. I'm thinking for the back i'll get AAL's. I'll have to run the front at 4ish to level out i guess, but I wonder if my cv axles will run ok?
  3. Nov 5, 2011 at 6:10 PM
    scalfee90
    Shane
    Sylacauga, AL
    Ok! Good advice! I'm going to do like you say and probably just go ahead and get my front diff drop just for piece of mind. Most likely ordering everything from Toytec so hopefully it will all go good.
  4. Nov 5, 2011 at 6:11 PM
    scalfee90
    Shane
    Sylacauga, AL
    I really need that picture I wasn't sure how they worked as far as ajustment!
  5. Nov 5, 2011 at 6:25 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea you can't go 4'' really without killing your CV joints.
    3'' is more then enough. A 2'' aal will level out the truck or slight bro lean. 3'' is levelish too and the 4''+is rake. when you pass 3'' in the rear you need extended travel shocks too and brake line and raise the BPV.
  6. Nov 5, 2011 at 6:33 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well i have 4.5'' of rear lift and i didn't puts those on for 4 months. Course i didn't wheel like that just street driving.
    the BPV valve definitely makes a difference tho, i felt a big difference when i did that. So really its prolly not a bad idea to do it with any lift.
    the extended brake like i think you'd be fine at just 3''. cause i was flexed out a few times and my line was pretty stretched but not terrible and that was a 4.5''. The line i got is super freaking long tho now. No way it'll ever get tight.
  7. Nov 5, 2011 at 6:43 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    lol sure! Im almost positive that that will hold the brake pressure Lol
  8. Nov 5, 2011 at 6:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :rofl:
  9. Nov 5, 2011 at 6:50 PM
    scalfee90
    Shane
    Sylacauga, AL
    Ok I'm going to get on this hopefully, I got to get me some tires after I recover from the lift. I'm shooting to be done by christmas.
  10. Nov 5, 2011 at 8:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    with Eibachs?? Get the wheelers AAL too
  11. Nov 6, 2011 at 7:19 AM
    Texasdynaryder
    Texasdynaryder Well-Known Member
    Chance
    Paris, Tx
    Kings Built Engine All the other small goodies
    I am purchasing the rear leafs one mine tomorrow... already have the Lr ucas and toy teche coilover boxed up in the shop ready to go on.... Any good ideas besides what yall mentioned here... Going ome 2.5 leafs ,bpv, all new bushings front to rear...
  12. Nov 6, 2011 at 12:17 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no its not. I have the 5 pk with the AAL and its shorter then the last leaf. THe 5 pk only gives like 1.5'' of lift man. I have the AAL and 1.5'' shackles and i get about 4.5 or so lift.
  13. Nov 6, 2011 at 12:21 PM
    Creepwood
    Creepwood Well-Known Member
    Lake Tahoe
    08 TRD 4X4 QCLB
    5100's w/885's up front, 5100's w/AAL out back
    Are you joking?? That is completely unsafe!
    You should use duck tape instead.
  14. Nov 6, 2011 at 3:49 PM
    marcchrisv
    marcchrisv Well-Known Member
    Gardnerville, NV
    99 Tacoma xtra, 2.7
    Toytec 2.5" lift., just the beginning. Front Builstein coil-overs fully adjustable from 0-3". 2" AAL in the rear with 2.5 degree shim. Total Chaos uni-ball UCA's.
    I agree with NMCQUEEN, get the toytec ultimate lift with the rear aal. I actually had a saggy leaf pack, and i haven't experienced any problems. I'm running 31's but i'm sure i could stuff some 33's under there with no issues (other than needing to adjust the bump stops so i don't rub when full tilt).
  15. Nov 7, 2011 at 8:15 AM
    marcchrisv
    Gardnerville, NV
    99 Tacoma xtra, 2.7
    Your best bet for tires/wheels i would go to tirerack.com (bought mine from them, all 5 for under 2K)(if you're ordering a combo they will mount and balance for you).
  16. Nov 7, 2011 at 8:19 AM
    marcchrisv
    Gardnerville, NV
    99 Tacoma xtra, 2.7
    Yes i highly recommend getting a longer brake line. I only have a 2.5" of lift, and when i dropped the rear drivers side during some wheeling i actually tore the brake line completely out of the fitting. Ended up driving all the way home using the E-Brake. Not fun, very dangerous, luckily i had a buddy in front of me that didn't mind if i bumped him in the rear to slow down. Still losing brakes is bad juju..
  17. Nov 7, 2011 at 8:38 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    that would suck lol i extended mine literally just before i went major wheeling to aviod that lol
