-   -   98 sr5 3in lift (http://www.tacomaworld.com/forum/1st-gen-tacomas/191555-98-sr5-3in-lift.html)
olshaner24 12-06-2011 04:22 PM
98 sr5 3in lift
hey, im lookin at puting a 3 in suspecion lift in my 98 sr5 4x4, anything i should be worried about? how long u think it should take? any special tools? o, gping in blind! thanks!
01Tac0ma 12-06-2011 07:31 PM
This is one of the most common questions asked on this thread, try using the search button nxt time but to answer your question you need to watch your cv angles and get a diff drop, should take you no longer than 4-6 hours doing basic spacer/aal lift but i wouldnt recommend spacers, if your going to do it right do it right the first time and go with a coilover type setup, with 5100's and your stock coils with the shocks set at 2.5" mark or just get the eibachs and elave the shocks at 0" mark and the only special tool i could think of is a ball joint seperator for the UCA...will make tings much easier but htats about all i can think of, ratchet wrenches would help to but not necessary.
Good Luck and be sure to post some pics when your finished!
