-   -   Destined for Disaster? Tac.Power Steering Pump Possible Bearing Noise...Drivable? (http://www.tacomaworld.com/forum/1st-gen-tacomas/199440-destined-disaster-tac-power-steering-pump-possible-bearing-noise-drivable.html)
flyingace83 01-19-2012 03:20 PM
Hey everyone, I have a 1997 Tacoma that is making a rachety noise at the power steering pump when spinning. I don't have money for a pump at the moment and the only way to make that money is to go work for it in that truck. Do you think I will be ok driving it or is it destined for disaster? What can I expect? Also if so, can anyone recommend any good pricing on the pumps as well? Thanks!
fsusteve 01-20-2012 08:24 AM
you can pull the belt and drive it fine, we drove ours with 35 BFG's for a few days when the pump went out, really wasn't an issue. You can get pumps anywhere for around $150. Check your build date because that affects which pump you need.
