-   -   95-97 Satoshi Build (http://www.tacomaworld.com/forum/1st-gen-tacomas/202201-95-97-satoshi-build.html)
MapleMoose 02-02-2012 10:06 PM
95-97 Satoshi Build
95-97 Tacoma Satoshi Write-up
I havent seem too many 95-97 satoshi grilles on here so i decided to give it a shot and make a write up. I wanted a color matched look so i painted it white.
Material List:
95-97 Painted grille - $30-$100
Toyota Landcruiser Emblem - $50 (PART NUMBER: #75311-90K00)
Perforated steel with round holes - $20
Color matched paint (2-3) - $30-$45
Black Gloss - $15
Clear Coat - $15
Epoxy - $5
Bondo and fiberglass - (had some laying around)
I also borrowed a dremel kit from a friend.
http://i1234.photobucket.com/albums/...2-02172625.jpg
http://i1234.photobucket.com/albums/...2-02172703.jpg
http://www.tacomaworld.com/gallery/d...live6M3MZT.jpg
http://www.tacomaworld.com/gallery/d...liveND5Ot6.jpg
I started off by buying a new grille so i could take my time with it. I went with a painted style so i wouldnt have to deal with the chrome. Made it way easier to sand and prep the grille.
http://i1234.photobucket.com/albums/...1-07133907.jpg
I cut out the horizontal and vertical members with a cutting disc on a dremel. I made sure it was as flush as possible without damaging it too much.
http://i1234.photobucket.com/albums/...1-09221046.jpg
I sanded everything down with 120 grit sand paper and wiped it with a wet cloth. I then prepped the side parts for fiberglass. First time using this stuff and it was messy!
http://i1234.photobucket.com/albums/...1-10175307.jpg
http://i1234.photobucket.com/albums/...1-10175319.jpg
Left it overnight to harden and then applied the bondo. Again this was the first time using bondo so it was messy.
http://i1234.photobucket.com/albums/...1-11150548.jpg
While the bondo was hardening, i traced the shape of the grille onto a piece of cardboard. I then transferred that onto my perforated steel. I cut the steel with a grinder and began sanding it down with 120 grit. I should have been using 400 grit too but i didnt have any. After sanding was done i sprayed it with brakleen to get rid of any rust or oils before painting.
http://i1234.photobucket.com/albums/...1-11150533.jpg
I did a couple coats of etching primer and couple coats of gloss black paint.
http://i1234.photobucket.com/albums/...1-11182619.jpg
Now back to the grille. I Sanded down the bondo after it dried until it was as smooth as could be. I then had to sand the edges down so the mesh would sit flush. I had to bring some parts of the edge up higher so it would make a straight line. I used a file.
http://i1234.photobucket.com/albums/...1-12133904.jpg
After that it was priming time. A couple coats of primer and a quick sand.
http://i1234.photobucket.com/albums/...1-12134610.jpg
http://i1234.photobucket.com/albums/...1-12165633.jpg
Painting time!
I couldnt find the exact paint match for my truck so i had to color guess. i ended up getting Nissan Super White for my mine. Worked out pretty well cause it matched up good.
http://i1234.photobucket.com/albums/...1-12170900.jpg
http://i1234.photobucket.com/albums/...1-25105915.jpg
Finished it with a couple coats of Laquer clear coat. Test fitted the grille behind and it looked great!
http://i1234.photobucket.com/albums/...1-13152921.jpg
Now one of the hardest parts was painting the headlight surround area. Taping it was not fun and i couldnt seem to prevent black paint from getting onto the my white grille. After a couple fails i finally got it.
http://i1234.photobucket.com/albums/...2-01120218.jpg
http://i1234.photobucket.com/albums/...2-01120230.jpg
After it was completely dry, i flipped it over and worked on the pieces that will secure the mesh to the grille. I bought some little zip tie things to epoxy to the inside grille.
http://i1234.photobucket.com/albums/...2-01120254.jpg
http://i1234.photobucket.com/albums/...2-01120309.jpg
Left it overnight to harden. I then cut up the small mesh pieces for the side vent parts of the grille. Primed and painted them and secured them using zip ties.
http://i1234.photobucket.com/albums/...2-01123504.jpg
http://i1234.photobucket.com/albums/...2-01123527.jpg
http://i1234.photobucket.com/albums/...2-01123540.jpg
All Done!
http://i1234.photobucket.com/albums/...2-01123732.jpg
TACOMABOSS 02-02-2012 10:13 PM
very nice :thumbsup:
Tacos Por Vida 02-02-2012 10:51 PM
nice write up, might have to do this one day.....
01tacoprerunner 02-02-2012 10:53 PM
Nice! Looks good!
cmack 02-02-2012 10:53 PM
:yawn:
Konaborne 02-02-2012 10:54 PM
looks good!
MapleMoose 02-02-2012 10:56 PM
Originally Posted by cmack (Post 4485700)
:yawn:
:wave:
cmack 02-02-2012 10:57 PM
Originally Posted by jr97tacoma (Post 4485709)
:wave:
Hi Buddy :)
livel0veryde 02-02-2012 11:00 PM
nice write up sir.
TacoMX 02-02-2012 11:16 PM
nice!
ilove_taco_ma 02-03-2012 11:45 PM
looks great. looking to getting a 4wd grille to replace my 2wd grille that is currently on the tacoma now.
MapleMoose 02-04-2012 03:10 AM
Originally Posted by 01tacoprerunner (Post 4485694)
Nice! Looks good!
Originally Posted by Konaborne (Post 4485704)
looks good!
Originally Posted by livel0veryde (Post 4485730)
nice write up sir.
Originally Posted by TacoMX (Post 4485780)
nice!
Thanks guys! I ordered a Landcruiser emblem today, should make it complete
Blackdawg 02-13-2012 06:04 PM
Bad ass bro! Very inspiring! I think ill do this this summer :cool: Lucky for me..the grill you bought already looks color matched to my truck so no painting for me :D haha...sept corner lights..
:thumbsup: Job well done!
45acp 02-13-2012 07:31 PM
:jerkoff:
Madjik_Man 02-13-2012 07:51 PM
I'd like to pull a "Danielson" and wax on and wax off to your truck.
96Taco 02-13-2012 08:02 PM
Awesome!
Where did you get your steel mesh from?
MapleMoose 02-13-2012 08:22 PM
Originally Posted by 96Taco (Post 4554165)
Awesome!
Local welding shop. Its called "perforated sheet metal"
Not sure what to say to that.... but thanks!
