what is over drive even for!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2002macdonald, Feb 19, 2012.
  1. Feb 19, 2012 at 1:39 PM
    2002macdonald
    2002macdonald [OP] Well-Known Member
    New Jersey
    02 4cyl 4x4
    In my 2002 taco i have the over drive option and i turn it on and off some times but don't notice much difference. i looked it up and the only thing i got was it gives you an extra gear how is that possible...
  2. Feb 19, 2012 at 1:40 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Oregon
    :confused:
  3. Feb 19, 2012 at 1:40 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Better hwy fuel economy. Go 55mph then turn it off and see what happens.
  4. Feb 19, 2012 at 1:42 PM
    2002macdonald
    New Jersey
    02 4cyl 4x4
    yeah the rpms go from like 4 to 2 1/2 but is that all it does
  5. Feb 19, 2012 at 1:43 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Pretty much. It just helps with towing/MPG
  6. Feb 19, 2012 at 1:44 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    Um... That's what it's supposed to do.
  7. Feb 19, 2012 at 1:44 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    http://en.wikipedia.org/wiki/Overdrive_(mechanics)
  8. Feb 19, 2012 at 1:47 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    You expecting a fucking rocket to pop out of the bed, Vin Diesel to jump in your open window into the passenger seat with a bottle of NOS hook it up while Mario Andriette straps a supercharger under the hood?
  9. Feb 19, 2012 at 1:48 PM
    AzogSS
    Andy
    Soda City, SC
    :rofl:
  10. Feb 19, 2012 at 2:01 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
    ^Don't forget the laptop you have to tinker with halfway down the quarter mile. :rolleyes:
    "Overdrive" is the 4th gear in the 1st gen. Taco. "Overdrive off" restricts the transmission to use gears 1-3.
  11. Feb 19, 2012 at 2:43 PM
    2002macdonald
    New Jersey
    02 4cyl 4x4
    alright karzie sj hey are u an emt?
  12. Feb 19, 2012 at 3:05 PM
    KenLyns
    Belly of the Beast
    What you are describing is the power take-off (PTO) function, which is only found on commercial trucks.
  13. Feb 19, 2012 at 5:50 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    My old man has tractors with PTO. I never knew thats what it did!
  14. Feb 19, 2012 at 6:43 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    Pretty sure the Trucks have 4spd w/ OD transmissions...meaning that there's 4 gears...then overdrive. So OD is 5th gear actually.
    But I wouldn't know too much about it because I have a real transmission :D (INB4 hate).
  15. Feb 19, 2012 at 6:45 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    All other gears reduce your engine output (ie, your engine is spinning faster than your tranny). Great for power/acceleration but poor gas mileage. Your OD gear is a big freaken gear that spins faster than your engine. Great for gas mileage but poor for towing, hauling, and accelerating. Its for cruising down the highway.
    The reason you have an option to turn it off is because sometimes while hauling, towing, or hill driving, your tranny down and up shifts frequently, constantly switching between power and gas mileage. By turning it off, you eliminate this.
  16. Feb 19, 2012 at 6:48 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    No, I believe its a 4sp (4th being OD). If you pay close attention to the shifts, you see 5 RPM drops, but I think the 5th is your lockup clutch. I could be wrong though.
  17. Feb 19, 2012 at 6:49 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I'm working right now. Sup?
  18. Feb 19, 2012 at 6:51 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    2002macdonald - "It burns when I pee. What should I do?"
  19. Feb 19, 2012 at 6:52 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Stop peeing would be my advice...
  20. Feb 19, 2012 at 7:03 PM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    Some of us A) Already have a 5speed as daily driver and B) require to tow, which auto trannies GENERALLY allow for a higher towing rate/capacity.
    Besides that in my particular case, I'm accident prone, and driving a 5speed with a cast is a biatch!
