Ball Joint Problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by scalfee90, Apr 3, 2012.
  1. Apr 3, 2012 at 6:46 PM
    scalfee90
    scalfee90 [OP] Well-Known Member
    Shane
    Sylacauga, AL
    1999 Tacoma Manual 3.4L
    Custom skid plate, rock rails, front bumper & rear bumper, pioneer head unit with 3-way pioneer components, blinker mod, Eibach coils, Bilstein 5100s, Procomp AALs, American Racing Sawblades, M/Ts, BPV Bracket, deckplate, LED Dash
    I'm having issues with my lower ball joints. I have replaced the driver side once and now its about 3 or 4 months later and its about to pop again. Is there any suggestions to permanently fix ball joint problems. I actually looked at greasable Moog ball joints. I would appreciate some help i don't want it to come apart while goin 70 and surely die on my way to work. :bananadead:
  2. Apr 3, 2012 at 6:47 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Oregon
    Go with the Moog lower ball joints. I just recently replaced my lower ball joints with Moog. They hold up to a lot of abuse and the ball joints are greasable..
  3. Apr 3, 2012 at 6:47 PM
    TacoBran
    TacoBran You're Unique, Just Like Everyone Else
    Brandon
    Peoria, AZ
    03 Double Cab 4x4 TRD SOLD, 02 Double Cab Pre-Runner
    Icon coilovers, TC UCA, icon shocks w/resi's, deaver leafs - 4x4 swap in progress
    How do you know when you have lower ball joint issues?
  4. Apr 3, 2012 at 6:49 PM
    scalfee90
    Shane
    Sylacauga, AL
    Actually with mine it sounded dry and no matter which way you turn or bumped it you could hear it squeaking like a ford explorer! :rolleyes:
  5. Apr 3, 2012 at 6:50 PM
    scalfee90
    Shane
    Sylacauga, AL
    Well problem solved I guess. Where is my best price on some?
  6. Apr 3, 2012 at 6:51 PM
    04LTtacoma
    Oregon
    Jack the front of your truck off the ground then take a crowbar and wedge it between the LCA and ball joint. If there is lots of play in the ball joint then you need new ones.
  7. Apr 3, 2012 at 6:52 PM
    04LTtacoma
    Oregon
    I bought mine from an alignment shop for $110 a piece. You might be able to find them cheaper online.
  8. Apr 3, 2012 at 6:53 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    advance auto order online use a discount code. just google for discount codes. has saved me a ton of money
  9. Apr 3, 2012 at 6:53 PM
    scalfee90
    Shane
    Sylacauga, AL
    Awesome, thanks buddy
  10. Apr 3, 2012 at 6:56 PM
    04LTtacoma
    Oregon
    If you purchase the greasable lower ball joints be sure to buy a pack of zerk fitting because the ball joints don't come with grease fittings.
  11. Apr 3, 2012 at 6:57 PM
    scalfee90
    Shane
    Sylacauga, AL
    Well dang! I would of went home without them too!
  12. Apr 3, 2012 at 6:59 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Its a lot easier if you jack up the truck by the arm, then put the crow bar under the tire and pry up. The ball joint will lift up and down in the arm if its loose. No need to wedge anything in your $2400 LCA's
    :eek: Rock auto has them for ~$44 each
  13. Apr 3, 2012 at 7:05 PM
    04LTtacoma
    Oregon
    I went wheeling last Saturday... Friday I had the truck in the alignment shop. They told me my ball joints were about to fall apart and they also showed me. I called every local toyota dealership to see if they had lower ball joints in stock unfortunately no one had any ball joints in stock so I decided I order a set through the alignment shop since the ball joints would show up in a few hours. So basically I only had a day to install those lower ball joints in order to go wheeling the next day. If I had gone wheeling without the new lower ball joints my truck would be toast. So basically I would either pay $88 for a set of ball joints and not go wheeling or pay $220 and go wheeling.
  14. Apr 3, 2012 at 7:16 PM
    TacoBran
    Brandon
    Peoria, AZ
    :thumbsup: thanks guys
  15. Apr 3, 2012 at 7:39 PM
    scalfee90
    Shane
    Sylacauga, AL
  16. Apr 3, 2012 at 8:31 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Damn, pay to play :)
  17. Apr 4, 2012 at 8:29 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
  18. Apr 11, 2012 at 5:07 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    1/4", 1/8", or metric zerk?
  19. Apr 11, 2012 at 5:10 PM
    04LTtacoma
    Oregon
    Not to thread jack, but does anyone have the moog outer tie rods?
  20. Apr 11, 2012 at 6:55 PM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    8mm zerks for the Moogs
