removing the shitty Trail master lift 97
Discussion in '1st Gen. Tacomas (1995-2004)' started by yamahahauler, Apr 30, 2012.
  1. Apr 30, 2012 at 2:32 PM
    yamahahauler
    yamahahauler [OP] Well-Known Member
    tyler
    Culver
    98 white
    bilsteins all around with emu springs.
    If anyone has removed this lift i would like to know some tips or should i just giver her hell! Never done suspension before but im not an idiot. never owned a taco before this. proud owner now:) and if anyone has upper control arms for sale that would be great i need them
  2. May 1, 2012 at 2:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I have a set of stock UCAs that I recently took off the truck. Send me a PM if you are interested.
  3. May 1, 2012 at 3:53 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    To remove the fail master drop bracket lift (I assume that's what it is?), you'll need to do a little welding too I think. All in all it's rather involved compared to removing a spacer set or something.
    It is still better than keeping that POS on though...DBs are bad news.
  4. May 1, 2012 at 4:00 PM
    yamahahauler
    tyler
    Culver
    98 white
    well first off im going to try to sell this rig and possibly pick up a stock tacoma.. there is a couple in my area that look like good candidates. If i cant sell it for what im asking then im going to take the time and take off the lift and weld in the 2nd crossmember in and hope its straight. doesnt seem like to much work just time and money i need UCAs and smaller tires.
  5. May 1, 2012 at 4:02 PM
    RattleTractor
    Harry
    VT
    '04 Unicorn Tacoma
    How many miles on the supercharger?
  6. May 1, 2012 at 4:53 PM
    yamahahauler
    tyler
    Culver
    98 white
    not sure i know if i end up keeping my rig im going to change the oil and rebuild it as much as i can the truck only has 146k and im sure that someone put the TRD supercharger on later
  7. May 1, 2012 at 6:55 PM
    RattleTractor
    Harry
    VT
    '04 Unicorn Tacoma
    I thought this over a bit. Here's what you do:
    1. Remove supercharger.
    2. Sell truck. That Fail Master lift is practically irreversible.
    3. Buy another 1st gen Tacoma with a V6.
    4. Install supercharger. Add other modifications as you want.
    5. ????
    6. Profit.
  8. May 1, 2012 at 7:57 PM
    yamahahauler
    tyler
    Culver
    98 white
    can you just remove the supercharger...is it that simple would i have to buy bigger injectors for the new truck?
  9. May 2, 2012 at 6:14 AM
    RattleTractor
    Harry
    VT
    '04 Unicorn Tacoma
    My understanding was that the TRD supercharger is entirely bolt on.
  10. May 2, 2012 at 6:27 AM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    it is entirely bolt on if you have the pink top injectors. they to like 385cc's or something which is more than enough to feed a s/c'ed motor on 12psi!
  11. May 2, 2012 at 8:07 AM
    yamahahauler
    tyler
    Culver
    98 white
    ive been running like 8 to 10..i didnt want to hurt the motor and just wanted to make it last
  12. May 2, 2012 at 8:15 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    the superchargers for the first generation tacomas do not come with larger injectors. And if the previous owner did a trail master lift I doubt they put in bigger injectors. You can pull the SC off without any consquences
  13. May 3, 2012 at 4:16 PM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
  14. May 3, 2012 at 11:34 PM
    yamahahauler
    tyler
    Culver
    98 white
    i just sold the truck today..... found a stock truck a year newer and i bought it alredy... i started putting the back shocks on about 10 minues ago.
  15. May 4, 2012 at 1:16 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    I think you made the right choice.
