Parking Break Locking Up
Discussion in '1st Gen. Tacomas (1995-2004)' started by bourdlay, May 2, 2012.
  1. May 2, 2012 at 7:37 AM
    bourdlay
    bourdlay [OP] Member
    Dave
    Michigan
    4x4 2.7 manual reg cab
    My passenger side rear break locks up when I set the Parking Break. If I jump under the truck and wiggle the cable where it is attached behind the break drum I can free it up. Do I need to replace the cable because of stretch?
  2. May 2, 2012 at 7:40 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    No it just needs to be adjusted. It's fairly straight forward, I think there is a How-To posted somewhere on here.
  3. May 2, 2012 at 7:41 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    CBI bed rack and sliders, Backwoods Adventure Mods front and rear bumpers, etc. And some stickers.
    Spray some WD40 on it but don't get any in the BRAKE drum.
  4. May 2, 2012 at 8:52 AM
    Madjik_Man
    Colorado Front Range
    You can adjust it very easily:
    http://www.lieblweb.com/ebrakeadjustment.html
  5. May 2, 2012 at 9:13 AM
    bourdlay
    Dave
    Michigan
    Awesome, thanks guys always a big help. I will adjust it tonite.
  6. May 2, 2012 at 9:28 AM
    takern
    takern Well-Known Member
    Tanner
    Virginia
    03 TRD Offroad stepside
    Deckplate mod, sliders, uniden cb, toolbox, dakar leaf pack, in search of coilovers, 255/85 16 bfg m/t waiting to go on
    you will probably need some pb blaster or liquid wrench. i had the same thing a few weeks ago and the bolts were on there tight
  7. May 2, 2012 at 3:04 PM
    pt law
    pt law Well-Known Member
    Steve
    Concord, NH
    04 xtracab 4x4 TRD
    Given that your in Michigan, I am willing to bet it is not your cable that needs adjusted. It is that the bell crank (where the cable attached on outside of drum) is getting stuck due to rust. That is why when you jiggle the cable it lets go finally. Happened to me recently.
    Here is a thorough write up on fixing the problem for good:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/140573-how-clean-bell-cranks-ebrake-stick-fix.html
    However, I took the cheap and easy way and sprayed PB Blaster inside the rubber boot and then worked the bell crank back and forth a bunch of times. Have not had a problem since.
    Either way, hope you get it fixed.
