Vibrations?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mxer256, May 8, 2012.
  1. May 8, 2012 at 3:11 PM
    Mxer256
    Mxer256 [OP] Well-Known Member
    Tyler
    Mississippi
    2012 Prerunner
    2012 Tacoma Trd sport, 10" bulletproof lift with traction bars and icon resi rear shocks, custom headlights and tail lights, 24x14 American force jades,37x13.50x24 Toyo mt, 1" borla wheel spacers, 30" lightbar, new build so more to come come
    I put a lift on my truck about 3 weeks ago. After i had the front installed i drove it and it was fine. Then I had a block for the rear and installed it. when i go about 25-30 it has a vibation to the whole truck. Anyone know what this is from? I know i need to get extended shocks but i know it wouldnt be that since it only does it at that speed. Thanks!
  2. May 8, 2012 at 3:19 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Looks to me like you've answered your own question.
    Its obviously the blocks. Take them out and replace with
    a new leaf pack.
  3. May 8, 2012 at 3:21 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    how would i know its for sure the blocks? And if i just got an add a leaf it would for sure help it?
  4. May 8, 2012 at 3:41 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Adding the lift in back has increased the driveline angle. The vib can be reduced or possibly eliminated by dropping the center bearing on the rear driveshaft.
    There are kilts available for this or you can do what I did. The stock bolts that hold the carrier berring in place are long enough to handle spacing down the bearing a little bit. I used about a 1/2" stack of washers to lower the bearing.
    You can find more information about this in the thread:
    http://www.tacomaworld.com/forum/1s...center-support-bearing-correct-vibration.html
    Here is a pic of the bearing and bracket.
  5. May 8, 2012 at 4:24 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    I installed a 4in. lift on my 99 prerunner. It took 3 1/2in blocks in the rear and I didnt get any vibation. So I dont think it is the block. Just my $0.02.:D
  6. May 8, 2012 at 5:09 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    Thanks! ill have to do this some time this week!
  7. May 8, 2012 at 5:10 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    Alright good! thanks for the help!
