What the f**k is wrong
Discussion in '1st Gen. Tacomas (1995-2004)' started by SpazzyB, May 10, 2012.
  1. May 10, 2012 at 1:26 PM
    SpazzyB
    SpazzyB [OP] Master of the Prius...
    Ryen
    neuf un six
    '04.5 vw stance machine
    Alright so like 2wks ago my alternator died and i replaced it, truck ran fine. 2 days later it dies, i check the alt and battery and both are fine. I replaced my fuel filter and its been running fine for about 2wks and randomly died on the freeway.
    Wtf is going on?! I'm seriously getting tired of this shit.
  2. May 10, 2012 at 1:30 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    you have a an electrical gremlin. replace the plugs and wires.
  3. May 10, 2012 at 1:32 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    If your ALT and Battery are good and not getting a solid ground could also cause this problem.
  4. May 10, 2012 at 2:33 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    If your truck was running good, and it just died, it could(should) be a short,
    we all make mistakes, I did a good one (dumb) years ago when changing my battery, I forgot to tighten down the neg cable, and it took a few days and it died coming down a off ramp, I freaked until i sat down and thought about it....
    and this is worse, but years ago my uncle had a smokey and the bandit trans am, and it would die every now and then from the day he bought it, it took a Pontiac engineer from the factory to find out that it had a short in the wire to the starter... dealer was stupid and my uncle was ready to sue....
    anyway, try to double check all the wires. good luck.
  5. May 10, 2012 at 2:49 PM
    SpazzyB
    Ryen
    neuf un six
    Replaced the plugs not too long ago, can't afford to buy new wires anytime soon so I guess i'm on a ground/short mission.
    fuck.
  6. May 10, 2012 at 2:55 PM
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
    Double check your main power wire to your starter, i had this same problem and found that the power wire was corroded all the way through the wire so it was making no connection.
  7. May 10, 2012 at 2:59 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    check all terminals, clean up the battery terminals and make sure they are tight still. if they're loose replace them.
  8. May 10, 2012 at 3:11 PM
    SpazzyB
    Ryen
    neuf un six
    I'll check the grounds/starter wire once the engine cools down.
  9. May 11, 2012 at 2:29 PM
    SpazzyB
    Ryen
    neuf un six
    Checked grounds and everything looks good. Starts but still wont stay running, even though first try it idled for roughly 15secs.
  10. May 11, 2012 at 2:36 PM
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    Have you done anything at all to the intake tract lately ? New CAI,new filter,K&N filter? Is that all tight? Check to make sure everything that was loosened/removed to change the alternator was tightened down properly.
  11. May 11, 2012 at 2:47 PM
    SpazzyB
    Ryen
    neuf un six
    changed the air filter a couple months ago, no cai or k&n filter. everythings tightened down and I checked for cracks.
    rechecked everything removed changing the alternator and it's all good.
    checked the maf and tps, both are fine.
  12. May 11, 2012 at 3:02 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Try swapping in a new EFI relay.
    The power outlet relay can be used, it is the same relay.
  13. May 11, 2012 at 3:23 PM
    SpazzyB
    Ryen
    neuf un six
    first thing I went too, underhood and dash panel.
    gonna give this a try right now.
  14. May 11, 2012 at 3:34 PM
    SpazzyB
    Ryen
    neuf un six
    Didn't work.
  15. May 11, 2012 at 3:42 PM
    jjew18
    jjew18 the Nightman cometh!
    John
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    When it dies, what is it doing? Any instrument flickering? Will it start without a jump?
  16. May 11, 2012 at 3:55 PM
    SpazzyB
    Ryen
    neuf un six
    Comes on with the rest of lights when it dies.
    Nothing flickers, just dies. "starts" without a jump but dies after like 3secs.
  17. May 11, 2012 at 4:06 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    If you want me to come over and see if I can pop some ideas for you. I'm no master mechanic but maybe I can help. I know you're literally a few blocks from me.... somewhere.
  18. May 11, 2012 at 5:53 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) Ryen, I am going to ask this question to see and try to insult you with it.
    Did you install the fuel filter in the correct direction ?
    Your problem is a fuel problem, you are running on what is in the line and the fuel pump is not running. If the gas filter is on correctly, then you may need to check for power at the fuel pump connection to see there is power. This sounds like a classic case of running out of gas. Good luck.
  19. May 11, 2012 at 6:02 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
  20. May 11, 2012 at 6:21 PM
    Schenko
    Schenko Member
    texas
    03 prerunner SR5 TRD
    this doesnt really count as a mod but i figured id say in this section that ill put up some pics of my truck after it gets fixed. some guy decided to turn into me and ruined the whole passenger side. truck is so tough the window and locks and door still work fine.
    i had a buddy with a similar issue caused by his ecu being a little loose. not sure if that will help but everybody already said the first things id check in trouble shooting this sort of thing so im trying to come up with some different possibilities.. ill try asking a few of my electrical specialty friends and let you know if i come up with anything. let us know if you figure it out
