transmission leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by radcat692000, May 13, 2012.
  1. May 13, 2012 at 1:28 PM
    radcat692000
    radcat692000 [OP] Well-Known Member
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    what the hell,, i just changed out the fluid in transmission ..did not over fill, now it looks like my transmission is leaking around the shifter area,,,hard to tell but it appears its comming from the top somewhere...leaking and blowing down towards the rearend,,rather annoying.. try to do a good thing and this happens,,any ideas what it may be??
  2. May 13, 2012 at 1:33 PM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    Could some of the fluid overflowed when you were adding it and rundown the outside of the input tube? Check the input tube and make sure it is not loose to where fluid may leak out. Does your dipstick show the fluid is at normal level?
  3. May 13, 2012 at 1:37 PM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    it hasnt leaked around input tube,,,its def comming from the top around the shifter area,,,i can see its very oily up there apparently it has been leaking for sometime,,
  4. May 13, 2012 at 3:30 PM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    guess i'm going to have tto pull the inside shifter area off and see if its a gasket or something leaking.. anyone know where i can find a blueprint of this transmission?? 3.4 liter 5 speed?
  5. May 13, 2012 at 4:15 PM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    took shifter cover off,,and you can def tell its leaking from the cover area,,,will work on it tomarrow..i'm running out of daylight..
  6. May 14, 2012 at 8:28 AM
    TMW
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Go here and scrowl down to your transmission.
  7. May 14, 2012 at 8:47 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Check the vents on your tranny, since proper fill is only about 50% full there is no way oil should be leaking from the top. If the vent is plugged it will look for a way to relieve the pressure though.
  8. May 15, 2012 at 5:30 AM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    didnt get a chance to work on it, but will soon,,,cleaning it up seems to be the 1st task at hand so i can see where its clearly leaking from... i'm going to drive it when its cleaned up to see if i can catch where the oil is comming from. (with the inside cover off,,so i can clearly look and see.)
  9. May 15, 2012 at 1:37 PM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    No dipsticks on manuals...
    OP - Did you fill using the fill plug or from inside the truck through the gear box? Like previously stated, its really only a 50% fill so its hard to believe oil leaks up that high.
  10. May 15, 2012 at 5:23 PM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    cleaned the top really good with purple power and a tooth brush,,,its def NOT leaking from the top,,,it looks as if someone has been into this tranny already judging by the reddish orange looking sealer they used,,but back to the point,,it looks like its leaking between the transmission and some sorta spacer plate between the transfer.
  11. May 15, 2012 at 10:50 PM
    apierce7565
    apierce7565 I eat terrorism and crap freedom!
    Anthony
    Fort Bragg, NC
    2004 Toyota Tacoma SR5 4x4 standard
    ARB Safari snorkel, snug top, snug rug, yakima rack bars, ARB front bumper, plasti-dip camper shell windows, sway bar removal, turn signal reposition, led dome lights, recon smoke roof cab lights, 8000k xenon HIDs, 5100 Billy coilovers and rear shocks, tundra leafs, 3 inch lift rear shackles, 315/75-16 Bfg km2, 16"/8" Eagle Alloy 100 series black wheels, grey wire mod, deckplate mod, diff breather mod, Rola roof rack with tire carrier, trimmed front and rear fenders
    i have the same problem! i replaced the seals and everything for my gear shifter and my 4wd shifter and its still leaking out of the 4wd shifter but idk why:/
  12. May 16, 2012 at 4:30 AM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    i'm taking it to the car wash and blowing it down really good under the tranny this weekend,,and searching till i find this fu*%N leak,,,i can't stand it...makes no sense ,, drain and refill, now leaking like a freaking sift. if i have to drop tranny i will,, but god i just put my suspension lift on last weekend,,i want to ride around,, not crawl up under this dang thing again,,:mad:
  13. May 16, 2012 at 4:37 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    New seals on an old, worn shaft wil normally not seal. The groove worn into the old shaft by the old seal prevents proper contact. A plugged breather will also cause a leak, as previously stated.
  14. May 16, 2012 at 6:34 AM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    well u can clearly see the wett look for the pics,,,i called a transmission guy here, (been doing it fior 25 years ) and he said it could absolutley leak from the top..to just try that 1st, and if thats not it,, no charge to just look and find the leak,,,you can't beat that,, so im going that route after i spray it clean...when it stopps raining, i'll update with what i did and find.
  15. May 16, 2012 at 7:13 AM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    I've run into the same thing on mine and knock on wood it is cured as not had a leak from them in a while now.
    First off the orange/red sealer stuff you see is the factory type fipg they use instead of using some paper gasket or the like. Does not mean the gearbox has not been into, but does mean that they at least used the factory gasket maker to put it together again.
    You could very well have a leak from the top shift plate. You have at least one vent there (round sort of nub sticking up off the plate). I pulled the shift plate off of mine, cleaned it up really well, sprayed brake clean through the vent area and got all the gunk off all over so it could breath free. I also made a gasket to fit under the plate using a roll of card gasket I had laying around. Coated the gasket with a thin layer of sealer all around and put it back together. Lastly I changed the small hose that runs from the transfer to the gearbox on the side there by the shifters.
    I also had two other leaks. One leaking from the plate between the gearbox and the extension housing and the other dripping off the bottom of the transfer case where the skid plate is. Transfer was definitly not leaking from around where the shafts go in. Those leaks ended up being the output seal on the gearbox and the input seal on the transfer case. Mine is a 1995 also so you should have the same part number seal for both of them. I'd have to go look to find the number for you if you need it. Replacement not too bad to do. Just a bugger to fiddle about with the odd shaped, heavy transfer case and align even with a trans jack to do the job.
    Hope that helps.
    Cheers
  16. May 20, 2012 at 4:00 PM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    It was the top shifter plate leaking,,,Got some cans of brake/parts cleaner and cleaned that baby up,,plus i used (below pics) this stuff i stole(borrowed) from my old job and it worked perfectly, i used it on the bottom and top of the oil splash shield and around the bolt holes... clean and oil free...:p
  17. May 22, 2012 at 8:26 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
  18. May 23, 2012 at 4:55 PM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    hope its fixed,,i will swear by this stuff i used,,we use it at work on oil pumps that flow 500 degree oil to a roller,,so i know it seals and will not leak..
  19. May 23, 2012 at 10:04 PM
    License2Ill
    Ian
    Yessir. Dun do believe she's-a-fix-a-roo-ed.
    $22 for the dealer's rtv, yikes, sore sitting down right 'bout now.
    Yeah, black RTV would of prevented the resurrection of Christ...:D Wouldn't worry about it leaking EVER again. Cheers.
  20. Jul 26, 2013 at 10:27 AM
    tacoma04
    tacoma04 Laissez les bons temps rouler
    Bruce
    Northern Louisiana
    2017 TRD OR DCSB BBP
    Best way to find out is to clean it real good and then watch it. Could be the gasket under the shifter plate???
