Clean Throttle Body & MAFS??
Discussion in '1st Gen. Tacomas (1995-2004)' started by NYProud, May 15, 2012.
  1. May 15, 2012 at 9:39 AM
    NYProud
    NYProud [OP] Active Member
    Chief
    OKC, OK
    98 Tacoma Ext Cab SR5 4x4 TRD
    CATZ Hyper White Fog Lamps in Front Bumper, LowRider Hard Shell Bed Cover
    I'm wondering if any of you guys make cleaning the throttle body and Mass Air Flow Sensor (3.4 V6 5VZ engine) a regular maintenance step.
    Is it a critical step, and if so, how often should it be done. I wanted to attempt it but, I read the MAFS is really delicate to mess with, and I have never tried to remove the throttle body.
    Would appreciate any information you can provide. My`98 Taco TRD 4x4 just went over 179K miles, and I'm trying to do everything I can to tweak performance....Thank you, as always...Chief
  2. May 15, 2012 at 12:43 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Cleaning the MAF is very easy to do. Just unplug the wiring harness it connects to and remove two screws. Pull it out and spray it down with some MAF cleaner. Just do not touch any part of the sensor itself. Not with the spray tube or your fingers. Let it dry and put it back together.
    I have not cleaned the TB yet, but it seemed pretty straightforward from a write up I saw on here.
  3. May 15, 2012 at 12:47 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    I clean both after each desert trip and every 10k miles or so.
  4. May 15, 2012 at 12:55 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    MAF
    TB
  5. May 15, 2012 at 1:06 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    That is throttle body cleaner, its by seafoam and does a better job than the run of the mill throttle body spray.
  6. May 15, 2012 at 1:17 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Yeah my truck runs funny if i do it into the vacuum line. I run half a can in the gas sometimes..
  7. May 15, 2012 at 1:31 PM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    CRC also makes a TB cleaner spray. I use that and the CRC MAF cleaner.
    Like mentioned above, do not touch the sensor with anything but spray. Also, clean out the carb in the MAF ring.
    Throttle body is straight forward... I removed mine so I could clean behind the butterfly plate and not get gunk in my IAC holes. 2 screws, 2 nuts, and 3 sensors to do this. If you do this, replace the gasket. A toothbrush is extremely helpful!
  8. May 15, 2012 at 3:54 PM
    CliffordBRD
    CliffordBRD Well-Known Member
    Cliff
    Tampa, FL
    09 DCLB 4x4 Pyrite Mica
    I just did mine not long ago, really helped out the idle stumble. Do it all at once if you do it, since the intake tube will already be disconnected from the mafs, might as well pull the other end. Mine was near black all around, took some work, but looks like new now!
    Good luck
  9. May 15, 2012 at 4:01 PM
    boshak
    AG
    CA
    Some TB pics before and after... Front and back... You can see the build up on the backside which is why I remove mine when cleaning. And yes I cleaned up the mating surface before reinstalling :)
    jammer likes this.
  10. May 15, 2012 at 4:03 PM
    boshak
    AG
    CA
    ^^^ this
  11. May 15, 2012 at 6:15 PM
    Dek Ngo
    Dek Ngo Well-Known Member
    D
    Austin, TX
    '96 4x4
    What's the part number for this gasket?
  12. May 15, 2012 at 7:10 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    Whenever I do my timing belt, I pull the TB and clean it. At the same time, I replaced the "D" shaped gasket with the supercharger gasket ("O" shaped, ie, more air flow). I did my first timing belt at 130,000 and the TB wasn't too dirty. I would say that it won't need it that often unless you are a desert runner type, like someone mentioned above.
  13. May 15, 2012 at 7:26 PM
    boshak
    AG
    CA
    I recommend asking your Toyota parts rep. Give him your VIN to be 100% sure.
    I've used engine part numbers from forums in the past and came to realize there were subtle differences even with similar engine types. For example, ECTS throttle bodies implemented in 2003, manuals vs autos, 4w vs 2w.
    Just my preference... Helps ensure I do the job once.
  14. May 15, 2012 at 7:27 PM
    boshak
    AG
    CA
  15. May 15, 2012 at 7:28 PM
    Muscles
    Muscles Well-Known Member
    Kyle
    San Diego
    05 PreRunner TRD
    K&N Air Intake
    use what?
  16. May 15, 2012 at 7:47 PM
    boshak
    AG
    CA
  17. May 15, 2012 at 8:10 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    Supercharger to TB gasket part number: 00602-17620-032
  18. May 16, 2012 at 6:07 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    I clean my MAF when my truck throws a P0171 code, which hasn't happened since I got rid of my TRD air filter and went with an OEM type.
  19. May 16, 2012 at 7:20 AM
    Madjik_Man
    Colorado Front Range
    The MAF I feel comfortable doing after reading several threads.
    But the throttle body still spooks me out.
    Is anyone will to make a video or extensive walkthrough on how to clean the throttle body? Would really appreciate it.
  20. May 16, 2012 at 8:13 AM
    boshak
    AG
    CA
