Opinions on wheel spacers?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jaren1512, Jun 21, 2012.
  1. Jun 21, 2012 at 6:37 PM
    Jaren1512
    Jaren1512 [OP] Well-Known Member
    Jaren
    Tualatin
    '98 Tacoma v6 SR5
    Deck plate mod, all chrome plasti dipped, 32" BFGs, fogs, 3" bilstein coilover 5100s/5150s in the rear, manaflow exhaust, smoked tail lights, rooftop lightbar, upgraded alpine sound.
    I just bought a set of wheels and tires on CL and found out the rims offset is too deep and wont let the wheel on the hub. I was told to get 2inch spacers but have heard some pretty trippy stuff about them. Ie: wheels flying off, spacers not seating right...
    Anyone have any advice?
  2. Jun 21, 2012 at 7:59 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Peeps in the baja 1000 race run wheel spacers. There is NOTHING wrong with them.
  3. Jun 21, 2012 at 8:02 PM
    Trigo
    Trigo Because fuck you that's why...
    Rodrigo
    San Diego
    1st gen
    ive seen a few mid travel trucks running wheel spacers so im :notsure:
  4. Jun 21, 2012 at 8:47 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    If they weren't safe why would we sell them?
  5. Jun 21, 2012 at 8:52 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    Just make sure they're not cast and manufactured from a reputable company such as Spidertrax, All Pro as mentioned above etc.
  6. Jun 21, 2012 at 9:42 PM
    Jaren1512
    Jaren
    Tualatin
    '98 Tacoma v6 SR5
    companies like les schwabb dont carry them anymore because insurance companies deemed them a safety risk. I have had a hell of a time finding a shop that has them.
  7. Jun 21, 2012 at 9:48 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Exactly. I've been running a set of 1.5 all pro spacers for 10k with no problems. If they are installed right then you will have no problems.
    Just don't take your truck to discount tire they won't touch anything with spacers on it.
  8. Jun 22, 2012 at 2:17 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I've had 1.5" spacers in the rear of mine for about 10k miles with no wheels flying off yet
  9. Jun 22, 2012 at 2:20 PM
    Sunner
    Sunner Well-Known Member
    I dont know how true it is but the only negative thing I read a while back was that they put extra stress on the balljoint on the LCA? Or something along those lines. :notsure:
    EDIT: Also, when I was having my spacers installed by America's Tire, the tech pointed out that even if the lugs on the spacer were to start to back out, they would not be able to clear off the stud since the wheel is right on top of them(not sure if all wheels will cover the spacer studs). So you'd know that its backing out by some pretty bad vibration before the entire wheel fell off.
  10. Jun 22, 2012 at 3:46 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Jason
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Just check the torque once in a while, make sure you use forged spacers and not crappy cast ones, they tend to loosen up due to the material.
    They do put more leverage on the bearings since the center is further out but it is what it is...2" seems pretty big, but if thats what you need then go for it, just check them often and you should be fine.
  11. Jun 26, 2012 at 7:13 PM
    woodbutcher
    woodbutcher Well-Known Member
    san jacinto ca.
    02 prerunner sr5 trd
    k&n intake, aftermarket wheels 16"
    good to see wheel spacers as a credible option update wanna know how that turned out for you.
  12. Jun 26, 2012 at 7:21 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    Thats true, but it is the same as having wheels that were equally backspaced.
