free wheeling hub assembly
Discussion in '1st Gen. Tacomas (1995-2004)' started by bduane, Jun 26, 2012.
  1. Jun 26, 2012 at 5:52 AM
    bduane
    bduane [OP] Member
    Bernie
    Mn.
    '99 tacoma
    lift,wheels
    '99 tacoma's lockout on the pass. side will only turn 1/4 way.took off cover and found no snap ring or center bolt. is there a video showing how to disassemble the hub so i can see what all may be missing? can't seem to find one on line. got a break down from the chiltons manual but doesn't really show much. and can a person get just the snap ring and bolt? went to o'reileys auto and they can only get the whole hub for around $275.00. rather repair the one i have. thanx much,bernie:annoyed:
  2. Jun 26, 2012 at 6:14 AM
    98tacoma27
    Ben
    Not Beech Creek
  3. Jun 26, 2012 at 11:09 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Manual hubs?
    Only ADD equipped trucks have the lock nut on the end of the axle. On a manual hub setup there is no nut, only a spacer that slides over the splines and a snap ring to locate the axle. Those 2 pieces are a dealer item I believe.
    If your hub wont lock, sounds like a hub issue to me in spite of the missing snap ring.
  4. Jun 27, 2012 at 8:15 AM
    bduane
    bduane [OP] Member
    Bernie
    Mn.
    '99 tacoma
    lift,wheels
    thanx for the feedback. got it figured out. someone had taken it apart and put it back together wrong(the hub). good to go now. thanx again.:burnrubber:
