Checking out a 96'. Any advice
Discussion in '1st Gen. Tacomas (1995-2004)' started by SpeedoJosh, Jun 29, 2012.
  1. Jun 29, 2012 at 2:31 PM
    SpeedoJosh
    SpeedoJosh [OP] Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Going to be checking out a '96 possibly tomorrow. It's access cab, V6, auto, 4x4, about 160K miles. Truck looks clean, and "no rust" claimed. Will def be looking for it. Anything else to look for on these.
    I searched around, and it appears the only difference in the late 90s to the early 2000s, is the grill. Everything else from drivetrain to most of the interior is the same on the 96 V6 to the 2003. Am I correct on this?
    Also, is around 6k a good price considering mileage and age?
  2. Jun 29, 2012 at 2:33 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Definatly check for rust.
    The three sub models from 1995.5-2004 were only small changes. Grille, lights, and some interior changes.
    6K sounds like a reasonable price
  3. Jun 29, 2012 at 2:39 PM
    SpeedoJosh
    Florida
    Yea, rust is my main concern.
    Another thing, is he has 32" on it without lift. Think that has done damage?
  4. Jun 29, 2012 at 2:42 PM
    TACOMABOSS
    96 SR5 4x4
    Also, if he has maintenace records thats a plus
    32s might have rubbed a little. I have 32s but Im lifted. Check in the wheel wells for rub marks
  5. Jun 29, 2012 at 3:33 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    Check c/v's and front diff for leaks. and look at ball joints.
  6. Jun 29, 2012 at 3:36 PM
    losers101
    losers101 Well-Known Member
    Brandan
    Texas
    2004 Dbl Cab 4x4
    Starting fresh :)
    The leaf springs from 95.5 to 97 are 3 inches shorter than rest of first gens
  7. Jun 29, 2012 at 3:37 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    stick your hand up in the frame by the front spring hangers and check for rust. Check ball joints and leaf springs as well, make sure they aren't broken or negative arch. 32's on no lift won't hurt a thing.
    I'd try and get it for 5500 if it's clean.
  8. Jun 30, 2012 at 12:21 AM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Ask about starter,water pump , radiator,and ignition. Mine had some tumblers wear down ,had to replace them.
    Check for cracks in the intake manifold,anything seen thru the heatshield is bad. *This is expected in older tacomas,use to your advantage*
    See if the spare tire tools are inside the cab.Google the vin and see if anything pops up.
  9. Jun 30, 2012 at 8:15 AM
    SpeedoJosh
    Florida
    Can you explain a little more about seeing through heat shield?
  10. Jun 30, 2012 at 8:46 AM
    n0ms
    Angel
    San Diego
    Heat shield has round cut outs in it. If the intake has you prob will see them . Most cracks are inbetween the 3rd and 4th tube on the intake.
  11. Jul 7, 2012 at 10:04 PM
    SpeedoJosh
    Florida
    Thanks for the advice. Ended up passing on the truck.
    "Runs great, no problems."
    Meet to see it.....
    (Granted it is a 97', so some of this was to be expected)
    Dent and dinged a fair amount
    Leaf springs are negative, or very close to
    Tires are rubbing big time
    Trim pieces scratched up/broken
    Grill half way about to fall off
    Hood had crazy amount of chips to the front
    Window button sticks
    No catalytic convertor
    CEL, assuming b/c of cat, not sure though
    Driver seat was worn pretty bad.
    Truck felt like it was "tired"
    Owner admits he's been towing boats way to heavy for it, "It'll tow 'em, just doesn't like it."
    Title had exempt marked on it for mileage. Could be an age thing I've found out, but didn't know at time.
    All in all, for 5k, it still might of been a decent buy, but didn't feel like the truck would last as long as other, better maintained, tacomas out there.
    Thanks for the advice. I'm still searching for that old gem :spy:
  12. Jul 7, 2012 at 10:12 PM
    Madjik_Man
    Colorado Front Range
    Sounds like the perfect truck to pass up.
