Removing throttle body now - need help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Jul 1, 2012.
  1. Jul 1, 2012 at 10:03 AM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    I can't the two hoses on the bottom backside off. I moved those metal hose clips back, but for the life of me I can't get the facking hoses to budge off of the necks they're on.
    They're the only things keep the TB on at this point. I'm afraid to get a flat head in there to pry them off (in fear of tearing the rubber hose(s) )
    Any help is much appreciated as soon as possible.
  2. Jul 1, 2012 at 10:06 AM
    Madjik_Man
    I'm pointing to the two facking stubborn things
  3. Jul 1, 2012 at 10:28 AM
    Madjik_Man
    nvm
    hoses off, TB out
  4. Jul 3, 2012 at 3:02 PM
    Bamahoyt
    Bamahoyt Well-Known Member
    Ted
    Knoxville, TN
    2014 TRD Sport DC LB 4x4
    Did you find A write up for cleaning your TB? If so could you post the link? Glad you got it off. I had the same problem a couple weeks ago on a sensor and the sensor actually broke when pulling on the hoses.
  5. Jul 3, 2012 at 3:05 PM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    just use throttle body cleaner and a rag
  6. Jul 3, 2012 at 3:57 PM
    Madjik_Man
    I primarily used this one:
    http://www.top4runners.com/ja/cleantb.html
    But had to call some audibles at the line of scrimmage once I was under there. Once you get into it, you'll see what you have to do.
    Off the top of my head I removed the bracket holding the cruise control and throttle cables... made life much easier and it was two 10mm bolts.
    edit, two more things: 1. Before you start undo the negative cable off your battery and remove the EFI relay in the fuse box in the engine bay, and 2. if you're going to tighten the throttle cable it is two 12mm nuts (not 14mm as written in that link). At least that's what it was on my truck
    Also, being a knob, I marked everything will tape so 1. I would know where it all goes back together and 2. would remember to put everything back together, eg hoses on necks, etc...
    Very simple and straight forward.
    The other thing I read on here is not to let all the crap from your throttle body drain into that hole that feeds your IAC valve/sensor. So when cleaning the throttle body, I always made sure that hole was at the top.
    Here are before and after pics of my throttle body. I didn't spend a crazy amount of time on it because my OCD would have had me sitting there for 6 hours cleaning it
    Front of TB before:
    Front of TB after:
    Back of TB before:
    Back of TB after:
  7. Jul 3, 2012 at 4:09 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Looks good. Don't forget to clean your MAF sensor while you're in there.
  8. Jul 3, 2012 at 4:10 PM
    Madjik_Man
    Yup did it at the time.
    On Sunday I:
    Cleaned the MAF
    Cleaned the TB
    Changed spark plugs
    Changed spark plug wires
    Tightened throttle body cable.
  9. Jul 3, 2012 at 4:16 PM
    scocar
    scocar hypotenoper
    You, sir, have now indeed earned the title Captain Awesome.
    I told you it was easy. :)
  10. Jul 3, 2012 at 4:16 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Just like Dick to call some thing easy.
  11. Jul 3, 2012 at 4:17 PM
    scocar
    scocar hypotenoper
    Jesus facking kryst. Just like Krazie to make something easy hard.
  12. Jul 3, 2012 at 4:17 PM
    Madjik_Man
    Yeah, I took my time with everything and all said and done it took me 3 hours.
  13. Jul 3, 2012 at 4:18 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I thought it was soft, not easy. :pout:
  14. Jul 3, 2012 at 4:18 PM
    Madjik_Man
    Just so long as he's not making Dick hard, we're all good
  15. Jul 3, 2012 at 4:20 PM
    scocar
    scocar hypotenoper
    I am not going to say anything about anatomy. I can see this is a tarp, and I'm not falling for it.
  16. Jul 3, 2012 at 4:21 PM
    Madjik_Man
  17. Jul 3, 2012 at 4:22 PM
    Madjik_Man
    Bish please. I got the blue NGK spark plug wires...
    ...I'm looking at at least 45 HP. The blue color makes more HP
  18. Jul 3, 2012 at 4:22 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Just don't ask Krazie to change your oil. :p
  19. Jul 3, 2012 at 4:24 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
  20. Jul 3, 2012 at 4:25 PM
    Madjik_Man
    After this weekend I realize I need some more skids underneath... primarily to protect the transfer case and transmission.
