what is this next to the auto shifter?
Discussion in '1st Gen. Tacomas (1995-2004)' started by nigglewiggle60, Jul 3, 2012.
  1. Jul 3, 2012 at 10:49 AM
    nigglewiggle60
    nigglewiggle60 [OP] Well-Known Member
    Nigel
    Oakhurst, CA
    2004 DC 4x4 TRD
    Rubber mats, Bluetooth.
    Don't know what it is called or what it is used for, but I have seen these in many of the auto trucks. It appears like something could clip in it or attach some how.
  2. Jul 3, 2012 at 10:51 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    At first when I seen this in the main feed I thought you were talking about the 4wd stick.
  3. Jul 3, 2012 at 10:52 AM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    Emergency release button, just in case it locks up. Had to use mine last week because a fuse blew and wouldn't let me shift.
  4. Jul 3, 2012 at 10:52 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    pretty sure it allows you to disengage park with the engine off so you can push the truck.
    edit: too slow
  5. Jul 3, 2012 at 10:55 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    So what do you do? Put something like your key in the hole and it pushes a button to release?
  6. Jul 3, 2012 at 10:56 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
    key works or a flat heads does the job. ive had to use it many times in the past. This caught my attention because i thought you were asking about the 4wd stick. Oh i wish the 2nd gens had that instead of a switch.
  7. Jul 3, 2012 at 11:31 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    this ^
    lets you shit it so you can put it in neutral if something goes wrong and it isn't letting you shift the normal way.
  8. Jul 3, 2012 at 11:32 AM
    Cr250jumper
    The moon
    50 shades of tan©
    :p
  9. Jul 3, 2012 at 11:32 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    damit:cool:
  10. Jul 3, 2012 at 11:43 AM
    nigglewiggle60
    Nigel
    Oakhurst, CA
    2004 DC 4x4 TRD
    haha, you guys crack me up. I feel like I'm going to enjoy it here.
    Sorry If the title mislead, but ultimately the question was answered. I tried searching, but it's hard to search for something you don't know what to call it.
    Now I know what to do to manually disengage the safety lock.
  11. Jul 3, 2012 at 11:51 AM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    I thought it was the mini-USB hookup for the Flux Capacitor...
  12. Jul 3, 2012 at 11:55 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    the what
  13. Jul 3, 2012 at 12:01 PM
    nigglewiggle60
    Nigel
    Oakhurst, CA
    2004 DC 4x4 TRD
    it's a "safety lock" so you need it in that gear to start. It locks in park when vehicle is off.
  14. Jul 3, 2012 at 2:43 PM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    ...it can be :anonymous:
  15. Jul 3, 2012 at 2:56 PM
    Cr250jumper
    The moon
    50 shades of tan©
    The "saftey" designed so you need the brake to shift out of park, so you dont accidentally put it into gear when your not expecting it. You can also start your truck in "N"
