16 inch wheels didn't fit
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sankuh, Sep 19, 2012.
  1. Sep 19, 2012 at 7:27 PM
    Sankuh
    Sankuh [OP] Active Member
    Nevada
    02 Ext. Cab 2.7 5 Speed
    Today I bought 2 separate set of 16 inch wheels from summit, just plain black steel wheels. And both times they did not fit. Both sets showed up as they would fit my truck, stock wheels 16 x 8, we tried different backspacing as well. Anyone know why rims keep hitting on the calipers?
    I want to get some new wheels but now I don't want to order a set just to find out thy won't fit.
    Or a good place to get the black steels wheels from?
  2. Sep 19, 2012 at 7:39 PM
    alexretama
    alexretama Well-Known Member
    Alex
    Long Beach, CA
    Depending on how badly you want them to fit, I've seen people shave their calipers with a grinder.. Also depending on where the calipers are making contact, theres a spec called the x-factor used to estimate caliper clearence. Its the distance from the back of the mounting pad to the back of the spokes..
  3. Sep 19, 2012 at 7:46 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I second this question and add: do you have VSC?
  4. Sep 19, 2012 at 7:52 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    I would not sacrifice a chance of an accident for some rims,
    personally OP I would just sell/return the rims and try again.
  5. Sep 19, 2012 at 8:33 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    because you need consider offset as well as BS'ing.
    the center chunk of the wheel must have the proper coning (flare)
    at the wheel's hub mount... to clear the calipers
    Not every wheel will fit... just because the BS'ing is correct.
    Many wheel retail shops... just don't really get that.
  6. Sep 19, 2012 at 8:37 PM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    OP can you post a link to the wheels you bought? Thanks. I've always had good results with Summit :)
  7. Sep 19, 2012 at 8:40 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
    For plain black steel wheels, order Toyota PN 42601-AF010, fits everything from old 100-series Land Cruisers to 2012 Tacos.
    EDIT: Hey! My gallery pic is nearly top-ranked on Google when searching for 42601-AF010. :)
  8. Sep 19, 2012 at 9:58 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Cool, what the hell is 42601-AF010 ??.....:notsure:
  9. Sep 19, 2012 at 10:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  10. Sep 19, 2012 at 10:55 PM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Don't do that. There's a liquid chamber behind that hump.
    Get these. Guaranteed fit. Wheeler's is good people.
  11. Sep 20, 2012 at 2:01 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    thats dirt cheap!
  12. Sep 20, 2012 at 3:21 PM
    KenLyns
    Belly of the Beast
  13. Sep 20, 2012 at 8:55 PM
    Sankuh
    Nevada
    My truck is a 2001 Tacoma Double Cab 4x4 TRD.
    The set of wheels that didn't fit were summit brand
    Here are the links:
    http://www.summitracing.com/parts/SUM-85-6883/
    I think I am just gonna go with the wheelers, since they are meant to fit.
  14. Sep 21, 2012 at 9:59 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    what about rocking a set of OEM FJ steelies?
    DustStorm4x4 likes this.
  15. Apr 9, 2013 at 7:11 PM
    AdmiralOtter
    AdmiralOtter Member
    AdmiralOtter
    NORCAL
    03 Tacoma TRD
    2" Spacer lift 265/75 r16 Terra Grapplers New Mods in the works
    where is the best place to get a set of those FJ OEM steelies for cheap?
  16. Apr 9, 2013 at 7:38 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Southern New Mexico
    2018 Tacoma TRD Off Road 4x4
    I Bought those exact wheels but in a 15" size. Mine rubbed the caliper so I put 1/4" wheel spacers up front. A lot of people say that they 1/4" wheels spacers don't leave you enough thread to grab onto. I've been checking my lug nuts every few days for the past 3 weeks and they haven't budged at all.
  17. Apr 9, 2013 at 8:46 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    that depends on what wheels and center chunk thickness.
    my current alloys are much thicker then what my previous
    wheeler's steelies were.
    I had to extend the stud length to compensate some.
    Probably not the case if running steelies.
    I recommend 8 - 10 turns of the lug nut, on the stud
    regardless of what wheel
  18. Apr 9, 2013 at 8:54 PM
    PcBuilder14
    Brent
    Southern New Mexico
    I think I went from 8-9 with stock wheels to 7 with the steelies. If they would have kept backing out, I would have just bit the bullet and bought some Wheelers Steelies. I got lucky though.
  19. Apr 9, 2013 at 9:08 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I've got a set of stock OEM steelies that I'm switching to, I think they'll look pretty good cleaned up & painted
    I have a set of old 8 spoke (look like old Jackman rims, which most of you prolly never heard of :D)
    They clear my calipers by 1/32 inch....:eek:
  20. Apr 9, 2013 at 9:13 PM
    KenLyns
    Belly of the Beast
    Picture or it didn't happen :p
    Here's mine with Konig Countersteers
