Can I fit in a one car garage?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sirsaechao, Jan 12, 2013.
  1. Jan 12, 2013 at 4:14 PM
    sirsaechao
    sirsaechao [OP] Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Due to recent car break ins and I have a lease until November. I want to get a 1 car garage in my complex. Width wise will I fit? What is the standard size of a one car garage and the width of my truck? I am more concern the width then height. Thanks.
  2. Jan 12, 2013 at 4:18 PM
    Domreis
    Domreis Well-Known Member
    Pullman
    Length would be more likely I would think. Garage sizes vary significantly. You'll need to get the dimensions from your landlord.
  3. Jan 12, 2013 at 4:19 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Are you actually asking about length? It's hit or miss, some apartment garages are big enough for a compact, some can fit a full size truck. Check one before you rent it. Width should be fine for any vehicle except maybe a dually. Most 1 car garages are the same door width.
  4. Jan 12, 2013 at 4:21 PM
    sirsaechao
    Tim
    CA
    I was told it is 11 x 22 and I am worried about fitting width wise through the garage door. I am also hoping the 11 x 22 the 11 is the inside width therefore my fat ass can still get out of the truck with the door opened up. I am more worried about the side mirrors hitting the garage opening rather then inside width and length.
  5. Jan 12, 2013 at 4:22 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Will they crack one open for you to try it out?? Seems like that is the best bet, if they will hook you up...
  6. Jan 12, 2013 at 4:25 PM
    sirsaechao
    Tim
    CA
    I took a rough rough measuring tape to it and it appears to be at least 8' wide maybe a bit wider and I think mirror to mirror we are at 7'? Not sure.
  7. Jan 12, 2013 at 4:27 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    An 8 foot door is typical for any 1 car garage. It will most likely fit but ask them before you pay.
  8. Jan 12, 2013 at 4:36 PM
    sirsaechao
    Tim
    CA
    Ok so I got the tape out and it is 8' wide. I shouldn't have a problem fitting right?
  9. Jan 12, 2013 at 4:43 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    It will fit. I park in the 3rd stall at my parents' house and it's 8' wide.
  10. Jan 12, 2013 at 4:47 PM
    sirsaechao
    Tim
    CA
    Yeah my calculations tell me this door is 8' by 7' minus a few inches due to trim I shouldn't have a problem. Now I just hope my truck doesn't get tapered with cause I don't get the garage until February.
  11. Jan 12, 2013 at 4:47 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    2010 Tacoma Regular Cab Slider
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    If anything height might be your issue..my wife got her 96 in my parents' garage easily side to side.
  12. Jan 12, 2013 at 4:55 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The only Tacos I've heard of having problems fitting are the 2nd Gen DCLB.
    1st Gen shouldn't be a problem... the DCSB and AC are the same length that Toyota trucks have been since the extended cabs were introduced and are only about two feet longer than a Corolla.
    1st Gen was 185in for a regular cab, about 202in for AC/DC.
    2nd Gen DCLB is 221"
  13. Jan 12, 2013 at 4:56 PM
    sirsaechao
    Tim
    CA
    I know I the antenna will for sure hit.
  14. Jan 12, 2013 at 8:14 PM
    CHPTR11
    CHPTR11 Team Impulse Red
    Dan
    Pacific NW
    2004 TRD Tacoma
    OME, Hankook, ARB, SCS
    I realize its all relative since garages vary widely, but for what it's worth, my townhouse has a double deep single wide garage and it fits with ample room on either side.
  15. Jan 12, 2013 at 8:15 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  16. Jan 12, 2013 at 8:38 PM
    Madjik_Man
    Colorado Front Range
    I have an extra cab.
    The width of my one-car garage door is 8 feet. Any narrower and it would be sketchy getting in without folding the mirrors.
    The interior dimensions of my garage is 24' x 10'
    At a minimum your garage would have to be 18' in length in order for an extra cab to fit. And mind you that wouldn't allow you to walk around the front or back of it.
    In terms of the width, 10' is enough for both the passenger and driver side doors to open and a passenger of my size (6' 190 lbs) to get out. The doors do not open all the way but certainly enough. You could probably get away with a narrower garage if you don't mind squeezing out the door(s) or if you're just solo and don't mind the passenger side not being able to open much.
  17. Jan 12, 2013 at 8:52 PM
    sirsaechao
    Tim
    CA
    Wow thanks for the photo. That's helps a lot.
  18. Jan 13, 2013 at 7:25 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I second the checking the height especially if you plan on lifting your truck any higher. My shop is underneath my regular DD garage. My FJ40 clears the top of the door by about an inch. I actually had to take the handle off. So I can't go any bigger than the 4" lift and 33's I have on it now. But the first thing to invest in is a tape measure!
