Where is the best place to get wires into the cab?
Discussion in '1st Gen. Tacomas (1995-2004)' started by dtmccray, Jan 12, 2013.
  1. Jan 12, 2013 at 5:29 PM
    dtmccray
    dtmccray [OP] Well-Known Member
    millbrook alabama
    01 money pit
    d60 3link sas, bumpers, sliders, arb twin on board air comp w/11gal air tank,38.5/14.5r15 tsl sx swampers, rock 8 beadlocks, detroit rear, trutrac front.
    Hi anybody know where the best place is to run multiple wires into and out of the cab on 1st gen?
  2. Jan 12, 2013 at 5:34 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    Under the carpet , there should be rubber plugs in several locations. Just cut a slit in the rubber and proceed with your wire, just silicone when you are done. Another good spot is the rubber grommet in the drivers side firewall.
  3. Jan 12, 2013 at 8:40 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    There are rubber grommets. One in each corner.
    Look in the engine bay corners. The secondary engine harness will be in them. Just poke a hole in them.
    In the rear of the truck they are under the rear seats in both corners.
    Passenger side rear
    Driver rear
    Here are the fronts.
    Kind of hard to see but they are in the very bottom part of the firewall in the corners. Well the holes anyways.
  4. Jan 12, 2013 at 9:12 PM
    dtmccray
    millbrook alabama
    01 money pit
    I used the grommet on the ds corner of the firewall. Going to put in an aux fuse block for lights,cb,winch remote and whatever other crap I put in so I won't have to run multiple power wires. I'll put up a few pics up tomorrow
  5. Jan 12, 2013 at 9:24 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That's what my first photo is. It's a relay/fuse box.
