-   -   Tacoma Stuttering when coming to a stop! (http://www.tacomaworld.com/forum/1st-gen-tacomas/262832-tacoma-stuttering-when-coming-stop.html)
Charlie76 02-11-2013 03:28 PM
I'm having a problem with my yota, the dealership i took it to didn't know how to fix the problem. When I come to a stop at slower speeds the truck "stutters" it's like the brakes are catching intermittently, but I know it's not the breaks. Anybody out their know about this problem?
JudoJohn 02-11-2013 08:06 PM
do you have ABS?
Charlie76 02-12-2013 05:58 PM
yes
Steves104x4 02-12-2013 06:07 PM
Extended cab? Check the driveshaft center bearing for excessive play. http://ts1.mm.bing.net/th?id=H.47363...=300&h=300&p=0 Check engine and trans mounts, too.
dentaco76247 02-12-2013 07:05 PM
warped rotors??
Pliny 02-12-2013 07:09 PM
Originally Posted by dentaco76247 (Post 6431149)
warped rotors??
This would be my guess for sure.
SwanksTaco 02-12-2013 07:10 PM
My old S10 did this, I took it somewhere and they trimmed the rotors and it was fixed. Costed $100 though..:mad:
tacoma04 02-12-2013 07:12 PM
Do you feel the brake pedal pulsate when it stutters?
outdoorames 03-06-2013 04:11 PM
This is what my '97 is doing (stock with ABS). Any further ideas?
tacoma04 03-07-2013 10:20 AM
Under normal braking, this is usually warped rotors. Your ABS will do this if it is a panic stop, but it normally won't with normal braking.
outdoorames 03-07-2013 11:42 AM
Interesting. I'll have to look into that. I have no other vibration when braking and the ABS engaging is inconsistent though sometimes very unexpected (normal braking into a turn or over a small bump...neither of which would I expect the wheels/brakes to lock up or skid). It seems overly sensitive. Thanks for your response!
Voyager 03-08-2013 12:35 PM
Lube the drive shaft fittings?
cscook1911 04-12-2013 02:21 PM
Hate to bring up an older thread but did you ever figure out the issue?
outdoorames 04-16-2013 12:35 PM
This may be coincidental, but I haven't had the same over-sensitive ABS issue since replacing the suspension (Toytec Ultimate Lift with Dakar Leafs).
DR007 04-16-2013 12:40 PM
I had a shutter too and its fixed now. I don't know much about all this but since I got my tires balanced it has gone away.
Charlie76 10-08-2013 12:47 PM
Same Problem
It is odd the problem i was having, just simply went away for these past couple months. I ended up dropping it off at a shop (didn't have time to look into it myself) they didn't find anything wrong with it themselves. So i kind of figured it worked itself out, but for the past month or so it has come back and is doing the same as it was before.
It's almost more of a "catch" now when just about at a full stop.
On gravel or on Slick roads the breaks will simply lock up. So i have to be sure to pump the breaks.
Getting a bit worried now being winter and snow is almost here.
I will set some time aside and check out the rotors, and everything else and see if i can't find something this time. I'll let you guys know. (Let me know if y'all have any more ideas as well)
tan4x4 10-08-2013 03:00 PM
How do you know its not the rear brake shoes grabbing?
Charlie76 10-10-2013 08:36 AM
If it is the rear brake shoes grabbing how would I go about fixing it?
