HELP!new head unit and tail lights and dash lights won't work
Discussion in '1st Gen. Tacomas (1995-2004)' started by RocktheRed, Mar 10, 2013.
  1. Mar 10, 2013 at 11:32 AM
    RocktheRed
    RocktheRed [OP] Guest
    Ok so I installed a new Kenwood KDC head unit yesterday and found that all of my dash lights and tail lights are out! I checked all fuses and they are fine...has anyone else has this problem?! Thanks guys! :)
  2. Mar 10, 2013 at 1:51 PM
    andrewprime1
    andrewprime1 Well-Known Member
    Andrew
    Salt Lake City, UT
    2007 Tacoma ExtraCab SR5 V6 6 Speed
    That definitely sounds like a fuse issue. Did you check both fuse boxes? I am new to Tacomas, but I am pretty ure most cars have two different fuse boxes.
  3. Mar 10, 2013 at 1:52 PM
    WailuaTaco808
    WailuaTaco808 A.L.O.H.A. Member
    Phil
    Hawaiian Islands
    2010 Tacoma TRD SPORT Kauai Built
    Oh boy...
    definitely a fuse problem
  4. Mar 10, 2013 at 3:55 PM
    Nunavut
    Nunavut Eh oh, Canada go.
    Canada
    It's probably a fuse in the engine compartment. I believe it's a 10a fuse.
  5. Mar 10, 2013 at 4:01 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Would've been better to post this in audio but, did you by chance connect the orange lead from the H/U (dimmer wire) to the stock harness? This seems to regularly cause what you've described. Search there and you'll get your answer for sure.
  6. Mar 10, 2013 at 7:55 PM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    I just went through an experience of recreating the stock harness wiring for my 96 in order to fit an OEM CD player in. The previous owner had done a hack job to install some POS JVC unit way back when.
    Check your fuses and double check your wiring - if you need help, my experience is still fresh enough that I may be able to help.
    Good luck.
    Also, what part of NoVa are you in?
  7. Mar 11, 2013 at 7:37 AM
    RocktheRed
    Dang you all are right and I'm terrible with any bit of wiring..it was definitly a fuse and an orange wire that was poorly connected. Other than that, the head unit looks fantastic and I'll need to upgrade my speakers and possibly to a bazooka sub!
    Moco- I'm in Burke, VA
  8. Mar 11, 2013 at 7:45 AM
    Moco
    Eric
    NoVA
    Good to hear you got it all figured out.
    Im in Arlington by the way. Honk if you ever drive by my truck.
  9. Mar 11, 2013 at 9:32 AM
    RocktheRed
    That's awesome, definitely will!
