-   -   Head light problems. No high beam (http://www.tacomaworld.com/forum/1st-gen-tacomas/273054-head-light-problems-no-high-beam.html)
04trd 04-13-2013 03:54 PM
Hey tw here's my problem. I have a 2004 dc yota with 132k. Recently I had a shop put in hids. They worked for 4 months now. Highs and lows working perfectly. got a new kit installed cause the old one was giving me problems like not turning on half the time and one light working while the other doesn't. Now the shop just called me saying I don't have any power going to the high lights. We took everything off and put it back to stock and still no power to the highs. We got power to the column and to the relay but we have no power to the high lights. Any one know a fix or ever have this happen fuses are good and no cut works. Any help would be great!
Yamaha Dave 04-13-2013 05:45 PM
Yes I had the same thing happen to me and had Toyota confirm it because it was under warranty. Basically your headlight switch has a short and will need to be replaced. You should have your DRLs working, but when you pull the switch for the highlights everything goes black. The headlight requires you to break into the steering column, And I would put my money on it that the shop who did your HIDs shorted it out.
04trd 04-13-2013 05:57 PM
My 04 never had dtrl but I will definitely look into it
04trd 04-14-2013 05:14 AM
Any one else have any idea where to even start to check stuff? If I have power at the column and at the relay under the hood I am assuming that means I have a cut wire some where?
TejasYOTA 04-14-2013 03:24 PM
Check the bulb, fuse, relay... Then if all is okay, then it's the switch.
Check the terminals, at both the switch and the connector at the steering wheel stock.
http://www.tacomaworld.com/forum/1st...ition-off.html
Might had shorted and burned the switch.
Only way to fix is to replace.
Yamaha Dave 04-14-2013 05:03 PM
I'm telling you it's the switch. If it was the fuse you would not have any ability to turn on the parking lamps. If you can turn the parking lamps on and off, but your highlights go off when you pull the switch, the switch is defective.
04trd 04-14-2013 05:22 PM
My low beams work just not the highs. So I will look for a new switch and the high beam indicator doesn't work either
Yamaha Dave 04-15-2013 10:15 AM
Like I said the switch. When you pull the switch you will not have the blue indicator light up on the dash.
04trd 04-15-2013 12:51 PM
Shiiiiit! That switch is 400 bucks!
Yamaha Dave 04-15-2013 02:03 PM
It's $50 bucks.
http://www.ebay.com/itm/SM1112-Turn-...7ad717&vxp=mtr
04trd 07-13-2013 12:51 PM
Hey kinda an update on what's going in. Got a new switch and still nothing. Everything is new. Hids. Ballasts. Fuses are good. Relays are good. I have no damn clue on where to look or even what to do?
ffirg 07-13-2013 01:55 PM
A few days ago I noticed my highs aren't working on my retros either. Connections are all good. Not sure what's wrong either.
04trd 07-13-2013 03:53 PM
Ya I'm at a loss. My next step is to return it all back to stock and send her to the stealer ship where ill have to cut off an arm and a leg to get it fixed than debate if I should put the hids on or not
04trd 07-13-2013 04:10 PM
And too add to this when I pull the switch to just flash my high beams the lights go in. Not sure if they are the high beams or not but I'm completely lost at this point
04trd 07-17-2013 04:45 PM
So here it is! My truck is all fixed up and back to stock. I talked to the guy who worked on my truck and he said that when tacos go from high beams to low beams the voltage changes between them. He said how they installed them it was only getting the low voltage side or the low beam. Guess what I have learned from this is DON'T KNOCK STOCK! And don't always think that a high end audio installer is always right installing stuff. But thanks tw for all the help!
vtrguy 07-19-2013 08:20 AM
This just goes to show that a relay harness is one of the first things you should do when you get your retrofit done/any HID install ;)
Good on you OP for getting it all figured out!
SMG 12-19-2013 06:38 PM
Hey guys,
The high beams just stopped working on my 04 TRD tonight. The lights don't work when you flick the stalk forward and there is no blue indicator. When you pull the stalk back all the way (flash) the high beams come on no problem and the indicator comes on. Any ideas? Any help would be much appreciated!
joes06tacoma 12-19-2013 06:43 PM
http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
Read this. It's for an older truck, but may apply to you. Sounds to me like you have a bad dimmer switch.
