-   -   Front end swap (http://www.tacomaworld.com/forum/1st-gen-tacomas/273933-front-end-swap.html)
ToyotaHi808 04-19-2013 01:28 AM
Front end swap
Does anyone know if you can put a 2000 Toyota Tacoma grill and headlight lights on a 1997 Toyota Tacoma?
therexinator 04-19-2013 05:38 PM
Not before doing a lot of other modifications. It takes a lot of work, you would have to replace the whole front end from what I know. Being bumper, hood, grille, and lights of course. Maybe do some more research. I have a '98 which is the same body style as the '00, those can be swapped with an '01-'04. Not totally sure on your situation though. Hope this helps.
therexinator 04-19-2013 05:40 PM
Try this link. I did some looking around and came up with this. Should be the same swapping into an '00.
http://www.tacomaworld.com/forum/1st...-end-swap.html
LSC15 04-19-2013 08:17 PM
Why would you want to switch, 95-97 is the best front end
4WD 04-20-2013 10:53 AM
I agree & if you study the looks of the '97 you'll see its the base look of what became the 2nd gens appearance
my '00 is an ugly duckling of tacomas
http://www.tacomaworld.com/gallery/d...48_Medium_.JPG
scoostraw 04-21-2013 06:55 PM
I know what you're saying, but I wouldn't go that far.. :cool:
Madjik_Man 04-21-2013 07:09 PM
The answer is yes. With not much to buy in terms of parts.
Search for "STLHarry and swap" He did the much more intensive 95-97 onto an 01-04. It's much easier to do within the two eras in the 95-00 range.
The only thing you'll have to figure out is one of the mounting bolts/holes on each headlight.
Another one who did the conversion (opposite of what you're thinking) is VirginiaBound
