Why is my 1999 V6 so weak?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TTBlues, Apr 19, 2013.
  1. Apr 19, 2013 at 12:28 PM
    TTBlues
    TTBlues [OP] Well-Known Member
    1999 Tacoma SR5 V6 4x4
    Stock
    This is the fifth Taco I've owned over the years. I love these trucks. My last one was a '04 Prerunner V6, my first V6. I liked the truck and it really had some balls. But alas, i sold it to buy a 4x4.
    I picked up a '99 V6 4x4 with under 95k, in great condition and was pleased as punch. But I just took it on a short trip up in the hills for the first time and have discovered that it is noticeably weaker than my '04 Prerunner, particularly on hills and passes. It maxes out at about 10 to 15 mph less.
    Is that expected? Was there a significant change in engine build between the '99 and '04 V6?
    is the weight difference between these two trucks really enough to account for a drastic difference in power?
    Or should I be looking into something in the engine that would account for this loss of power?
    I just got the service records from the delearship and they show that at the 60k service the prior owner reported sluggishness on hills and lean run condition. The MAF was changed and that improved it. But I'm not so sure it fixed it entirely.
    I'm going to swap out the plugs and wires and see if that helps, but is there something else I should look into, or is it just a normal difference between the trucks? What part of the engine would breakdown and account for the disparity? The truck runs fine otherwise. It's fine on flat ground. I didn't notice all this when I test drove it because I live in a relatively flat area.
    In my '04, if I wanted, I could cruise up hills at 80 mph no problem,. In this truck I have it almost floored at around 65mph, with chevy's, fords, and nissans passing me left and right. It feels more like a 4 banger to me or like I'm hauling rocks. And I can't pass people and look like the cool guy in the Toyota!!
    Thanks!!
  2. Apr 19, 2013 at 12:36 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    John
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    any CeL codes auto man ? wouldnt hurt doin a tuneup plugs wires seafoam changin all the fluids including diffs and t case
    if u think its that bad maybe a compresssion/leakdowntest?
  3. Apr 19, 2013 at 12:41 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    x2.
    But I agree with you OP I have a 99 V6 as well and it seems pretty sluggish on hills. Granted I have a 3in lift and skinny 32's but I don't think my tires are much bigger than stock.
  4. Apr 19, 2013 at 12:45 PM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    You've tried basic maintenance? I did a bunch of stuff on my car when I bought it (a 97) just because it's old and I assumed no one did. Fuel filter is a big one, no one ever changes them. Air filter, plugs?
  5. Apr 19, 2013 at 12:53 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
  6. Apr 19, 2013 at 12:54 PM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Except he's comparing apples to apples, right? Did the 3.6L change between 99 and 04?
  7. Apr 19, 2013 at 12:57 PM
    TTBlues
    Stock
    Both the trucks are automatic and xtra cabs. same bodies, same weight load. I had the timing belt done asap as well as the other belts and hoses, etc.. Put a new air filter in it. The plug wires and MAF sensor were changed at 60k. I just picked up some new plugs from the stealership, but I haven't put them in yet. We'll see if it improves after that and some fluid changes. If not, I schedule a compression test.
  8. Apr 19, 2013 at 12:58 PM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Definitely hit the fuel filter while you're at it. Every used car I've bought has had the original one still in there, and unclogging it really helps. Only $20 for a new one.
  9. Apr 19, 2013 at 1:00 PM
    TTBlues
    Stock
    Fuel filter.......roger that!
  10. Apr 19, 2013 at 1:02 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    gawd...
    ....he is comparing 190HP to 190HP expected
    yep, the derp is strong in me today :anonymous:
  11. Apr 19, 2013 at 1:18 PM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Could also be exhaust - o2 sensor, clogged cat, etc. That's all pricier though... But someone who is smarter than me will probably chime in.
  12. Apr 19, 2013 at 1:23 PM
    taco terror
    taco terror 1st gen = best gen
    North Carolina
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    My truck feels sluggish, but that is only because it has 31's instead of the stock 28's.
    Does the truck have larger than stock size tires? Check the sidewall and compare it to the tag in the door jam.
  13. Apr 19, 2013 at 1:30 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    could be a clogged up cat
    wait...let me rephrase that
    could be a clogged up cat :anonymous:
  14. Apr 19, 2013 at 1:56 PM
    TTBlues
    Stock
    yeah, the door calls for 15's and the truck has 16's. Would that make a HUGE difference?
  15. Apr 19, 2013 at 2:42 PM
    TTBlues
    Stock
    to be more clear: the door calls for: P225 75R15
    the truck has on it: P265 75R16
  16. Apr 19, 2013 at 2:43 PM
    TTBlues
    Stock
  17. Apr 19, 2013 at 2:45 PM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
  18. Apr 19, 2013 at 2:48 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    also depends on the type of tire.
    I used to run 235/75r15's on AT's
    now I run 265/75r16's on load range E MT's
    huge difference
  19. Apr 19, 2013 at 2:50 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Yeah, my 96 T100 4x4 with 3.4 took a huge hit going from aluminum wheels with P rated tire to steelies with Es.
    what are your mpgs OP?
  20. Apr 19, 2013 at 2:53 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Just more food for thought, the fact that your 04 was a prerunner and this one is 4x4 will probably make a noticeable difference. All that extra weight under the truck means it will be slower and get worse mpg. However all these ^ suggestions will probably help too. :D
