-   -   HELP!!! bad bucking and jerking (http://www.tacomaworld.com/forum/1st-gen-tacomas/274259-help-bad-bucking-jerking.html)
tacocass 04-21-2013 01:20 PM
First, 02 Taco 4x4 3.4l: I was driving in second gear yesterday coming off a stop and went wot to pass someone. Next thing I know the check engine light is flashing at me, and the vehicle is violently bucking... Since yesterday, I have changed all 3 coils, plugs, wires, fuel filter, pcv, and maf... No change and all are oe componets. The vehicle starts and idles fine. It only misfires under load( climbing a hill or in first gear), or wot. It will only misfire after 2300rpm. Please help this is my dd... I am lost.
tacocass 04-21-2013 01:21 PM
oh ya and no stored or present codes...
Aught2TaCO 04-21-2013 01:43 PM
Has the timing belt been changed? Don't know if it is that, I'm just throwing it out there.
2000GTacoma 04-21-2013 01:46 PM
don't think the timing belt would cause this. If it jumped time it would run bad at idle...maybe a fuel delivery issue or spark issue.
Aught2TaCO 04-21-2013 01:52 PM
Just thought of that after I hit enter lol. I was thinking of valve float at high RPM, but that happens primarily with pushrod engines that I'm more familiar with.
newertoy 04-21-2013 01:55 PM
HMMM !
tacocass 04-21-2013 02:03 PM
The timing belt was replaced 2000 miles ago. The truck only has 91k. Just removed the timing cover and it hasn't jumped time... It feels like it hits a wall when it misses... Just removed both cam and crank sensors, no cracks in them...
tacocass 04-21-2013 02:04 PM
I would say valve float, but this is happening around 2500rpm and up...
camt10 04-21-2013 02:08 PM
Lights flashing indicating catalyst poss damage usually indicating lean mixture if you have access to a fuel gage attach and monitor under load see what psi is doing. That's a start also if u have access to a cheapo scan tool see what fuel trim and oxygen sensor readings r
Aught2TaCO 04-21-2013 02:13 PM
I was pondering fuel pressure too.
tacocass 04-21-2013 04:11 PM
Update, p1135 o2 code just popped up... Going to Advance to pick up a denso sensor. Thanks to any and all who have helped so far. What is fuel pressure supposed to be? I did not see any test ports on the fuel rail?
camt10 04-21-2013 04:45 PM
Did u test the sensor output,ie resistance check could be bad if its original which sensor is that can't remember is that pre cat or post.fuel psi if I remember is around 40 either way should be constant what u would be looking for if it was an issue is drastic decrease when engine exhibits mis.no fuel Schrader u have to tee in to fuel line.who knows you might get lucky with o2 sensor if u need specific info I can get it at work tommorrow.
tacocass 04-21-2013 05:24 PM
Short term is 0% lt is 10.2%... My upstream sensor 1 o2 is showing 0v at idle. When throttle is pressed it hits .72v. I'm gonna start there and hope this works...
camt10 04-21-2013 05:35 PM
At 2k rpm does the sensor cycle or stay constant o2s should cycle
tacocass 04-21-2013 06:06 PM
cycles .2-.4v
camt10 04-21-2013 06:31 PM
Check that the sensor has its full range ie lean mixture out see out put
Richer check output
tacocass 04-21-2013 07:24 PM
Well trying to remove the sensor the stud to the converter broke, cross threaded... Whomever owned this taco before me did a number. Found an exhaust leak near the sensor, and it's a Bosch 02... The factory converter looked to be running pretty hot, gonna change it.
camt10 04-21-2013 07:47 PM
Is the element in cat melted? They do run pretty hot,also what stud,mounting stud for 02?
tacocass 04-21-2013 08:08 PM
ya stud for the dang o2... The cat was almost glowing red, and caked with red clay! I've been scraping clay off of this thing since I bought it. I don't know if the element is melted, but I dont see how else to replace the stud...
camt10 04-21-2013 08:12 PM
Is the stud flush or some sticking up
