Help on front spacer lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03tacoman, Apr 26, 2013.
  1. Apr 26, 2013 at 5:09 AM
    03tacoman
    03tacoman [OP] Well-Known Member
    Eric
    Southern Maine
    2003 Sr5 v6 Ext Cab
    I am in high school and found this on craigslist for real cheap. I might not even use the AALs for now because later on i plan on buying a billys lift with wheelers AALs but for now would it be fine if I used these 2" spacers up front? As a leveling kit. Who has used these before and did they make the ride with stock coils better, worse, the same, etc... and YES I KNOW SPACER LIFTS ARE JUNK but i'm doing it for looks to get me by because it's cheap.
    here's the craigslist link...
    http://maine.craigslist.org/pts/3764080814.html
    ..remember
    :worthless:
  2. Apr 26, 2013 at 5:35 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Don't waste your money. Get some Bistein and set them in the middle setting and call it good. Wasting money on parts you won't use and a spacer puck that'll soon be replaced. Just save that money for some Bilstein. Plus why waste money on alignment after the spacer then again when you get Bilstein 5100's? That's cash you can put into your suspension funds. Save your money.
  3. Apr 26, 2013 at 5:37 AM
    03tacoman
    Eric
    Southern Maine
    2003 Sr5 v6 Ext Cab
    oh shit yea forgot I would have to align it after. thanks
