-   -   Ignition Switch (http://www.tacomaworld.com/forum/1st-gen-tacomas/275732-ignition-switch.html)
Newby 04-30-2013 04:57 PM
Ignition Switch
Hello,
I have a 96 Tacoma SR5 V6 4x4 with 262xxx Miles. There is no light comes on. The Ignition Switch was bad and every time I turned the Engine off, I could not turn the Ignition Switch to the Lock position so I could not pull the key out. I left the key in there in the ACC position for several days and the Battery was out then I could turned to the Lock position and pulled the key out as normal. Yesterday I just bought a new Ignition Switch from Toyota Dealer to replace it. Also I recharged the Battery, but after I finished installing the new Ignition Switch, I tested it and it worked fine, but it did the same thing as it did before with the new Ignition Switch. Do you have any idea why? I need your help please.
Newby 05-01-2013 06:51 PM
Any idea, guys.
Newby 05-04-2013 08:11 AM
It sometime works fine, but sometime it does not. Did any of you have the same or similar problem as I do now?
Ray Beeze 05-06-2013 03:29 PM
Automatic transmission?
Newby 05-09-2013 06:36 PM
Yeah, it's automatic transmission.
I found out, not 100% sure, the problem is the key interlock solenoid.
Ray Beeze 05-11-2013 01:07 PM
I had the same problem and found the shift lock control switch was bad. The transmission didn't know it was in park and wouldn't let the key turn to the off position. I umounted the console at the base of the gear shift and bypassed the switch; remounted the console and the ignition switch works fine now.
The only side effect is: you can shift out of park without having to depress the brake pedal and you can turn off (and remove) the key from the switch while the gear shift is in any position. Not necessarily a bad thing, just mentioning it.
http://i44.tinypic.com/332zfjr.jpg
Newby 05-14-2013 04:59 PM
Great. It's a good reminding.
I removed the front cover (under the steering wheel) and unbolted the Key Interlock Solenoid for several days now and it works fine. In this case, can I just leave it unbolt and put the front cover back in? Is it safe?
Ray Beeze 05-15-2013 12:27 AM
It shouldn't hurt anything. If the connector has any exposed contacts, tape them to prevent a short circuit and it shouldn't be a problem.
Lol, you and I operated on opposite ends of the same circuit: shiftlock control ecu sends impulse signal to the key interlock solenoid.
