-   -   New engine or rebuild? (http://www.tacomaworld.com/forum/1st-gen-tacomas/276520-new-engine-rebuild.html)
emjidi 05-05-2013 08:39 AM
I have a '96 Tacoma that overheated and hasn't started since. When I took it to a mechanic, he said that gas isn't getting to the engine and suggested installing a new engine which would cost a little over $3000. What do you think about this price and would it be more cost-effective to rebuild the engine? My friend said he would help me with the rebuild if I chose to go down that route. :confused:
RJ MacReady 05-05-2013 02:27 PM
I'd prob rebuild it & go from there. It won't cost $3K if you keep it stock. Theres a few places that actually do installs with warranty in the La Verne/Glendora area.
Bmack04 05-05-2013 11:31 PM
your "mechanic" said that you need a new engine because gas isnt getting to the engine? if u need a new engine due to the fact it overheated real bad, i might believe that. his story isnt added up to me...
Dcpsychobilly 05-05-2013 11:34 PM
X2
Another story about a mechanic trying to pocket more money
Op get second opinion and a real diagnose
emjidi 05-06-2013 12:18 PM
Thanks for the input guys, ill get a second opinion before I proceed any further.
Fenwick1993 05-06-2013 12:32 PM
x2.
06yfz450ridr 05-09-2013 08:17 AM
2jz swap haha thats what im doing when my motor goes, you can pick up the motor, the turbos and ecu etc together for like 1800 and with th 5 speed tranny it will work with some sort of adapter i believe but the tranny would need to be rebuilt to handle that as well as new clutch depending if its auto or standard
colby8100 05-09-2013 10:50 AM
Do not do 2jz swap waste of time and money especially if you have a 4.0 I've done it I dot over 11000$ in mine and I should've done turboed lsx
colby8100 05-09-2013 10:55 AM
A good gte is going to cost close to 3500 $ you should still tear it down replace gaskets put arp head studs you can build 700hp of of a stock gte you just have to change turbo, header, exaught , fuel injectors, computer, clutch, cams pretty much everything and that far into it go ahead and build bottom end
colby8100 05-09-2013 10:57 AM
Ps boosted cars are faster if auto because it doesn't blow off in between shifts
Dcpsychobilly 05-09-2013 11:31 AM
Op update?
06yfz450ridr 05-10-2013 08:22 AM
true but used without a rebuild you can find them decently cheap, and i just love the sound of the 2jz. ahh i need a supra
colby8100 05-10-2013 10:50 AM
If you want a 2jz and have it cheep and decently quick get a ge vvti engine from junk yard throw it in turbo it with a single turbo the manifold is less than 200 $ you'll probably be fine with reliability under 500hp but torque would be a lot better due to higher compression and vvti
2013TuRD 07-11-2013 01:32 PM
Have you heard of a diverter valve? AKA blow off valve if it's vent to atmosphere? It allows the turbo to spin with less restriction for the short period of time during a shift. Works great on my turbo Miata.
colby8100 07-12-2013 06:20 AM
Na I don't worry about it. I let off the trans brake and bump the shifter twice and maintain over 30psi through prettt much the whole pass. Plus manual cars have the risk of missing a gear
BamaToy1997 07-12-2013 06:29 AM
Would be an impressive engine in a Tacoma. Just an expensive swap. Would need a custom programming I would think for the ECU for the VVTi to work. I would like to see it tho!
tacomataco2 07-12-2013 07:05 AM
1st gen section. No 4.0's here
