tranny swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by corey84, Jun 5, 2013.
  1. Jun 5, 2013 at 6:30 PM
    corey84
    corey84 [OP] New Member
    pheba ms
    96 tacoma 4x4
    Hey, I'm new to the forum any help wold be greatly appreciated. I have a 96 tacoma 4x4 v6 auto. The trans give up on me I was wanting to know what it would take to put a 5 speed trans in it. Thanks for any help.
  2. Jun 5, 2013 at 6:37 PM
    dand
    dand You can't see me
    Dan
    SE VA
    2020 MBM TRD Offroad MT
    1st stage commencing
    Oh, I'm sorry, was expecting something else. ..:eek:
  3. Jun 5, 2013 at 7:38 PM
    Madjik_Man
    Colorado Front Range
    Search for a member SafetyDang. He swapped his double cab auto for a manual. And he's all smart and stuff too.
  4. Jun 5, 2013 at 7:39 PM
    661prerunner
    661prerunner Well-Known Member
    Santa Clarita
    01 prerunner
    FabTech C/Os, Solo tubular UCAs (on order)Solo spindles(not installed) Glassworks front and rear, made by me Rocksliders, Premier Navi,
    :rofl:
  5. Jun 5, 2013 at 7:58 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Lets see..
    Tranny, r151, including everything..
    Master cylinder
    Slave cylinder
    Clutch pedal and all parts
    And most importantly a new ECU that's for a manual.
    Either new harness or custom hack your current one.
    New center console..
    Think that would be the basics..
    I'm not sure on drive shafts or transfer case.
  6. Jun 6, 2013 at 5:15 AM
    corey84
    pheba ms
    96 tacoma 4x4
  7. Jun 10, 2013 at 11:02 AM
    SafetyDang
    SafetyDang get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
  8. Jun 10, 2013 at 2:22 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    Don't forget the flywheel, clutch assy. it may have a different driveshaft, too.
  9. Jun 10, 2013 at 6:21 PM
    SafetyDang
    Dang
    Anaheim, CA
    My best advice its to save for a doner Tacoma. Part out what you don't need and do your swap. After doing the swap I spent the same amount I would have if I bought a wrecked rig. Mind you I did also do a 4x4 conversion at the same time. On to of that I also bought after market parts here and there.
    Good luck with your swap.
  10. Jun 10, 2013 at 11:08 PM
    RJ MacReady
    RJ MacReady professional trousersnake charmer
    RJ/Mike Hauncho/HeavyHands
    US OUTPOST North 31-Mayday Mayday! We've found som
    00 4Runner 4WD LTD - Cheatin' Bitch Build 2
    Cheatin' bitch build 2: All stock for now... 99' Tacoma 4wd TRD Cheatin' bitch build 1: BG44K additive, motul 5w40(always), deckplate mod, K&N washable air filter, 2.5" flow master(cut thanks to Airdog), king fronts 2.5", all pro standard leaf pk, stainless steel rear ext brakeline, 5125's 10" travel rears, 4-jasper offroad 6" pod LED spot lights, secret compartment for small bottle of wild turkey, cobra CB, Hi-lift jack w/locking bed mount, hi lift curved bumper lift & road base plate, smittybuilt X20 winch, wab fab F&R bumpers w/ hitch receivers, smittybuilt 4in1 recov tool, 10gal mini flamethrower, 11 lbs dynamite sticks, 13 4-hr snowflares, .50Cal full auto mounted machine gun w/ RPG unit & a shitoad of death metal to fuckstart your brain...everything you need for first contact with a shape-shifting alien entity frozen for over 100,000 years reanimated & immitating all life it engulfs.
    i was just thinking, "what exactly"
