03 Double Cab roof rack removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by justcuz, Jun 8, 2013.
  1. Jun 8, 2013 at 5:49 AM
    justcuz
    justcuz [OP] Well-Known Member
    is there a way of removing the factory roof rack
    from my 03 Double cab?
    will anyone be able to tell if it was ever installed after removal?
  2. Jun 8, 2013 at 6:56 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    my factory rack, a Perrycraft, is screwed directly into the roof's sheet metal so it would def be noticeable. I suspect the same applies to your rack..
  3. Nov 19, 2013 at 3:28 AM
    Edlo
    Edlo Member
    Ed
    Los Angeles
    Just a stock 4x4
    I'm curious why are you removing it, i'm thinking about putting on an OEM rack. Is it loud?
  4. Nov 19, 2013 at 6:34 AM
    Tribull
    Tribull Have more than you show. Speak less than you know.
    Little Rock, AR
    2021 Toyota Tacoma TRD Offroad 4x4
    Bone stock. For now.
    If you do remove it, I will gladly buy it from you.
