Vibration at all speeds
Discussion in '1st Gen. Tacomas (1995-2004)' started by webb323, Jun 18, 2013.
  1. Jun 18, 2013 at 6:47 PM
    webb323
    webb323 [OP] Well-Known Member
    Jordan
    Tennessee
    97 4x4 Regular Cab (sold), 2014 Double Cab TRD Sport
    I have a 97 4x4 Regular Cab Tacoma. I've had the truck for a little over a year and the whole time I've had it it's had a vibration. The vibration is in the steering wheel and it gets really bad at different times. Its gotten worse so I started trying to find the problem. I have
    -Put new wheels and tires on it(balanced the old and new ones with beads and weights)
    -new rack and pinion and tire rod ends( tie rod ends were busted and rack was leaking)
    -new u joints
    -checked for warped axles and didnt find one
    I have struts ordered because they are shot but I dont really see this being the problem.
    Any more suggestions of things I could look at or try?
  2. Jun 18, 2013 at 6:49 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    check your u joints
  3. Jun 18, 2013 at 8:57 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 PreRunner TRD V6
    - OME suspension - Custom front/rear tube bumpers - 33x12.5r15 BFG KOs - Deckplate mod + AFE reusable filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - Pioneer stereo and new speakers + 10" sub - camper shell
    warped brakes.
    bad wheel bearings.
    can you identify if it's a front or rear vibration?
  4. Jun 19, 2013 at 4:45 PM
    webb323
    Jordan
    Tennessee
    New rotors because it needed them and ive checked the wheel bearings by checking for play in the wheels. And I believe that it is a vibration in the front end because it shakes the steering wheel so bad. It also has a Toyota brush guard on it(its kinda flimsy), any chance that could be it?
  5. Jun 19, 2013 at 8:11 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    ball joints is your last thing, and carrier bearing
  6. Jun 20, 2013 at 5:26 AM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    does it have wheel spacers? my truck had some really cheap wheel spacers when I first got it and the steering wheel shook like hell while driving. check on that and if you have them, remove them and see if this helps.
  7. Jun 20, 2013 at 5:29 AM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    i wouldnt think it would be ball joints. i had some real bad ball joints on my truck and the inner and outer tie rods were worn out and i didnt get a shake like the OP is saying.
    Did the wheel weights fall off maybe?
  8. Jun 20, 2013 at 8:00 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    His truck does NOT have a CENTER bearing.
    Could be a bad ball joint, though.
    Suspension bushings?
    Steering damper?
  9. Jun 24, 2013 at 2:56 PM
    webb323
    Jordan
    Tennessee
    I dont think the ball joints are wore out, I jacked the truck up and used a big bar to check for play in the ball joints. Like someone said I dont have a carrier bearing. I also do not have any wheel spacers. What suspension bushings would be wore out? And whats the steering damper?
  10. Jun 24, 2013 at 7:47 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Could be the bushings in your UCAs...mine are bad as we speak and i'm getting shakes too. I bought new bushings from SPC (Light Racing) and need to replace them.
    Could be your steering rack bushings as well...you'll get some vibes if those are shot.
  11. Jun 25, 2013 at 9:31 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    OKAY...
