suspension lift questions???? help!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by loonskier13, Oct 17, 2013.
  1. Oct 17, 2013 at 4:47 PM
    loonskier13
    loonskier13 [OP] Member
    2002 reg cab 4wd 5 spd taco.
    3 inch tuff country suspension lift. 31 inch tires.
    I want to buy a TUFF country 3 inch suspension lift. (( here is the link )) http://www.suspensionconnection.com/cgi-bin/suscon/529043.html?gclid=CObvwPb7nroCFYqZ4AoduywAvg.
    It says its a suspension lift.... but why does it have lift blocks for the rear????. Isnt that a body lift???. and also is this a good lift?? All im looking for is a 3 inch SUSPENSION lift. But i just want to know if the lift blocks are like placed under the springs or under the frame of the truck. Also if I get this with lift blocks will it be bad for my truck.
  2. Oct 17, 2013 at 4:51 PM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    It is a suspension lift because the block goes under the leafs and not the body. As for the quality I know people that own rough country lifts not for tacomas but they hate it
  3. Oct 18, 2013 at 12:39 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No its not a good lift. Thats a spacer and block lift. Pretty much the cheapest crapiest lift you can get.
    Do some more searching on better lifts.
  4. Oct 18, 2013 at 1:01 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Try the Toytec Ultimate lift kit
  5. Oct 18, 2013 at 7:23 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    Maybe he just wants a spacer lift to stick a bigger tire under there. Maybe we should qualify what he wants to use his truck for before shoving an over priced lift down his throat when in fact he may not need to use it. I sell spacer lifts all day long for people who just want a larger tire. Its better than a body lift. Only those who are going on the trails and using their truck in the mud or the mountains will I then suggest a control arm, coilover or drop bracket lift.
  6. Oct 22, 2013 at 9:15 AM
    Ian.S
    Ian.S Well-Known Member
    Ian
    Harlingen, TX
    2016 TRD OR DC Infernooooo
    It's the little things.
    I just got a similar lift. It doesn't ride very well but it gets you bigger tires and that's what I got it for.
    It's not bad for your truck, but I wouldn't count it as a major offroad performance upgrade other than greater ground clearance.
    :thumbsup: to offrdmania
    And I would add the shock absorber option for sure!!
  7. Oct 22, 2013 at 12:02 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The blocks go between the rear leafs and the axle.
    Not the best lift, but it is cheap.
