Lack of Power
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacosoup89, Jan 15, 2014.
  1. Jan 15, 2014 at 11:50 AM
    tacosoup89
    tacosoup89 [OP] Active Member
    Carrollton, Ga
    2003 2.7L PreRunner
    Ok so my 2003 2.7 doesn't like cold or damp mornings anymore and I don't know why anymore. Ive been scratching my head on this for months. Took it to a mechanic to see if he could figure out what was wrong with it and it didn't throw any codes. Ive replaced the spark plugs, ignition coils, fuel filter and attempted to change the MAF sensor but the truck rejected it despite my many attempts, just wouldn't take it ran like shit or not at all. Any ideas anybody? Truck just picks and chooses what days it runs right, likes to bog down on an ant hill even after its had time to warm up.
  2. Jan 15, 2014 at 11:53 AM
    tacosoup89
    Carrollton, Ga
    2003 2.7L PreRunner
    Also my truck has 130k on it if that help diagnosing it.
  3. Jan 15, 2014 at 12:00 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Does it lack power at all RPM's? Just when taking off, or at all speeds? Manual or Automatic transmission? Does it run fine at idle, skip or miss at all that you can hear, or does it miss when you get onto the gas? Do they have to be cold AND damp, or does just cold or just damp cause the problem as well? Does the problem get better, worse, or go away once the truck is warmed up?
    Have you noticed a drop in MPG's lately?
    Also, do you run your defroster at all on warmer days, when the truck isn't having issues?
  4. Jan 19, 2014 at 11:20 AM
    tacosoup89
    Carrollton, Ga
    2003 2.7L PreRunner
    The problem mainly is at acceleration and from then on it just bogs down on hills. The problem is on both cold and damp days. The problem seems to show itself mainly at around 2,000 rpm my normal cruising rpm then bogs down and will usually downshift. The problem gets a little better after its warmed up but hills are still an issue. I haven't noticed any drop in mpg and yes I run the defroster every morning. I preciate the help guys sorry it took so long to get back to yall.
  5. Jan 19, 2014 at 11:47 AM
    Card1
    Card1 Well-Known Member
    Georgia!
    96 taquito
    Doestch Spindles
    Mine does that too.. 96 2.4L auto tranny with 170k. It sucks man, i thought about cleaning out my intake and everything but i doubt it'd do much. PM me if you get any info on it
  6. Jan 19, 2014 at 12:00 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Could be one of the sensors is going bad. Lots of them on the truck, and they all tell a story to the ECM, and it reacts to it.
    Find out what the resistance values are supposed to be and check as many as you can.
  7. Jan 19, 2014 at 3:16 PM
    tacosoup89
    Carrollton, Ga
    2003 2.7L PreRunner
    Yeah thanks for the input guys. I keep coming around to the same conclusion that I just have to start replacing sensors one at a time. I think ill just about have a whole new engine before this is all over. Gonna try replacing one of the O2 sensors next then I guess the fuel pump.
  8. Jan 19, 2014 at 3:17 PM
    tacosoup89
    Carrollton, Ga
    2003 2.7L PreRunner
    Im open for suggestions if anybody has any. Im not made of money so if somebody can point me in the right direction that would be great.
  9. Jan 19, 2014 at 3:33 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    John
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    So does it seem to idle good all the time? If its just when your driving it pulling hills etc sounds like it could be transmission related?..
  10. Jan 19, 2014 at 3:41 PM
    tacotundra
    tacotundra Well-Known Member
    Check your injectors.. Im pointing toward that or you could start to have a fuel pump going bad not pumping enough fuel to the engine or it can be the fuel regulator could be bad..
    Edit this could also be a sensor dropping out on you like your MAF or cam sensor... Only way to correct check those is with a lab scope..
  11. Jan 19, 2014 at 3:56 PM
    tacosoup89
    Carrollton, Ga
    2003 2.7L PreRunner
    It idles great. Wasn't sure if it might be the injectors? Do you reccamend a good cleaning or replacement? I also have considered the transmission because it being an auto. Do the autos have any bugs Im not aware of?
  12. Jan 19, 2014 at 5:21 PM
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    Same, idles great, but bogs for a few miles. its fine when it's warmed up but i don't like how it reacts at the beginning.
  13. Jan 19, 2014 at 5:30 PM
    Noelie84
    Noel
    Wales, Maine
    Before you worry about pumps and injectors, have you ever replaced your fuel filter? When was the last time you replaced your air filter? Also, at the risk of sounding obvious, have you checked the fluid level in your transmission?
  14. Jan 19, 2014 at 7:04 PM
    tacosoup89
    Carrollton, Ga
    2003 2.7L PreRunner
    The fuel filter is brand new. Since you brought up the transmission fluid I will give that a check since I don't check it too often. I did replace the fluid about 30k miles ago and checked it a few times since. Would a clogged transmission filter possibly cause my problems?
  15. Jan 20, 2014 at 4:42 AM
    Noelie84
    Noel
    Wales, Maine
    Oh, right. You mentioned fuel filter in the first post, I just missed it. Whoops.
    Every clogged transmission filter I've seen has resulted in hard shifting, not in a lack of power. I suppose it's theoretically possible that it could cause a lack of power...
    Usually it causes transmission slipping or hard shifting, though.
  16. Jan 20, 2014 at 7:35 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    It is temp related it sounds like so change your air temp sensor located in your air filter box. Its about $20 at your local auto parts store and doesnt hurt to change if its isnt the culprit.
  17. Jan 20, 2014 at 7:52 PM
    Card1
    Georgia!
    96 taquito
    Doestch Spindles
    Any luck OP?
  18. Jan 21, 2014 at 3:25 AM
    tacosoup89
    Carrollton, Ga
    2003 2.7L PreRunner
    Ok ill look into that air temp sensor. The truck just has a mind of its on it seems. I appreciate the help guys. Im just gonna continue changing sensor like ive been doing and hope I hit the right one. My friend has a Honda crv that had an O2 sensor go bad on his car that had some similar symptoms so maybe ill start with it.
  19. Jan 21, 2014 at 3:38 AM
    tacosoup89
    Carrollton, Ga
    2003 2.7L PreRunner
    Does anyone know why my truck wouldn't take a new MAF sensor? Tried every trick that I could come up with and my truck just ran rough or not at all. Im thinking this could be a problem indicator or a crappy new sensor??
  20. Jan 21, 2014 at 6:52 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    07 Lexus GX470
    I would clean the O2 sensor before actually buying one, no sense in throwing parts at it if you don't know the real problem. You should take it to the dealer and have them run it with their scanners to help pin point the problem.
