01 2.4L automatic trans not shifting correctly
Discussion in '1st Gen. Tacomas (1995-2004)' started by springfield59, Jul 9, 2014.
  1. Jul 9, 2014 at 10:20 PM
    springfield59
    springfield59 [OP] Member
    Craig
    Tuscaloosa
    2019 Tacoma automatic 2.7L I4 access cab
    intermittent wipers, Kobalt truck box
    I have a 2001 Tacoma with a 2.4L automatic transmission (A43D) that was rebuilt at 211K and now has just over 300k on it. Changed the fluid recently and it does not shift correctly, may require high revs to finally shift, so I now shift manually from 1 through 3. Can anyone advise what I need to be looking at or checking out to finally solve so I can just put it in drive and let it shift on it's own? Thank you.
  2. Nov 7, 2014 at 1:46 PM
    gearcruncher
    gearcruncher Well-Known Member
    Canadain bumper technician
    Great white North 51.0333° N, 93.8333° W
    2010.TRD.SportDCLB4x4Limited leather package
    TRD Sport Rally -5 speed automatic Limited ,Factory heated leather seats ,chrome package,Super white with front windows tinted to 35 % Dick Cepek DC-2 wheels Summer tires - Good year silent armor P265/65R17 Winter tires - Good year P265/65R17 Ultra Ice studded Illuminated 4x4 switch TRD 3rd brake light cover ($20) TRD seat belt shoulder protectors (5). ($50) TRD ...B pillar emblems ($20) TRD rear slider sticker with devil horns ( $6) TRD summer floor matts ($60) TRD steering wheel emblem ($20) TRD floor pedals .($95) TRD shorty antenna ($14) TRD front Windshield emblems ($17) TRD head pillows .($60) TRD head rest protectors TRD door scuff protection $20 TRD floor matt emblems ($40) TRD tow plug emblem . ($40) TRD cigarette lighter with LED.($35) TRD tissue dispenser ($12) TRD front bezel emblems ($9) TRD door emblems ($6) TRD lanyards($9) TRD lisence plates with TRD bolts($50) TRD fender emblems TRD center caps Part Number:PT904-35070-CC ($80) TRD cd
    You have a computer controlled transmission . Next step woule be making sure the fluid is full and then scan for codes
  3. Nov 7, 2014 at 4:46 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    2006 4runner sport 4.7L V8 (white)
    used to have - 99 2.4L I4 5 lug & 04 prerunner v6
    umm you did use the correct fluid when you changed it right? its an easy mistake to make
    Mush Mouse and Brie like this.
  4. Nov 7, 2014 at 7:07 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I thought these only came with manual transmissions and the 2.7 had the option of both?
  5. Nov 7, 2014 at 7:51 PM
    bhale001
    bhale001 New Member
    NY
    03 tacoma dlx
    Your shift points are mechanically controlled by a TV cable or Kickdown cable. Its a cable that goes from your throttle plate to your transmission. My truck wouldn't shift out of first gear the other day. The cable was stuck wide open. Check to see if the cable moves freely.
  6. Nov 7, 2014 at 8:00 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I worked on a 01-04 truck with the 2.4 and auto trans, they're out there.
  7. Nov 7, 2014 at 10:24 PM
    2004TacomaSR5
    Jon
    Montana
    OP it could be a number things, shift solenoid could be out, or the pressure solenoid could be out. I had this same problem with the transmission in my Monte Carlo and it was both of them gone out. Your torque converter may be locking up and not releasing at the right time also.
    Brie likes this.
  8. Nov 8, 2014 at 8:12 AM
    keakar
    karl
    louisiana
    no, they always had autos but the factory puts out like 40% auto and 60% manuals so you see a lot more manuals then autos
  9. Feb 18, 2017 at 6:58 AM
    JWR5
    JWR5 Member
    98 Tacoma 2.4 AT A43D
    As bhale001 stated I believe the kick down cable is seized in the wide open throttle position on the 98 I am working on. This truck is my daughters friends truck, her starter was out, old brittle tires replaced, were not safe, she had spare on and tire in bed was mostly fibers hanging from rim! Wasnt shifting to 2nd gear till 35mph, 3rd at 70mph! Messed around with kickdown cable and know she wont shift out of 1st gear at all. I noticed the cable had a lot of slack in it. When I rotate the throttle to full stop the kickdown cabel is still loose. I pulled and pushed on it and know NO SHIFT AT ALL! At the transmission cable is above Park safety switch? On far end of shifter rod shaft. Behind exhaust and Cat, hard to access. Took screw out of Park switch but just rotates, adjustment screw i think? How do I remove cable from tranny??? Looks like maybe there is a big nut at end of shifter shaft that if removed would allow park switch to come off? Maybe then I could see cable end at tranny? No manual please help, already spent too much on someones elses vehicle, know it wont shift.
