What is the cheapest way to drop my 2wd taco?
Discussion in '1st Gen. Tacomas (1995-2004)' started by emglishe30, May 4, 2009.
  1. May 4, 2009 at 2:15 PM
    emglishe30
    emglishe30 [OP] Well-Known Member
    NJ
    2010 SR5 Base 4x4 DCSB
    Pioneer Touch Screen, Sub, Diode Dynamics SS3 Sport amber fogs, Oem skid plate, led accent lights, led 3rd brake, 2011 color matched honeycomb grill. Plasti dipped pieces.
    I am looking for an easy and cheap way to drop my 2wd taco. How to do it? Stuff I need to get to do it? Etc...
  2. May 4, 2009 at 2:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. May 4, 2009 at 2:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im sorry.....I had to....:)
  4. May 4, 2009 at 2:25 PM
    emglishe30
    NJ
  5. May 4, 2009 at 2:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Someone will be hear to help ya...:)
  6. May 4, 2009 at 5:39 PM
    emglishe30
    NJ
    Might I mention its an 01
  7. May 4, 2009 at 5:55 PM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    8112, SPC, Elka 2.0 rear and Icon AAL. About 1.5”
    Cut the coils, and remove a leaf??? :confused:
  8. May 4, 2009 at 6:06 PM
    emglishe30
    NJ
    Thats what a buddy and I were thinking. What would be the outcome by going this route?
  9. May 4, 2009 at 6:31 PM
    tacoholic
    tacoholic Well-Known Member
    East Bay, CA
    Well you would have shocks designed for the current length but like 2 inches shorter so you could top them out over speed bumps and ruin your shocks. Or, it could work perfectly forever. I would buy stiffer springs and cut them...if that's able to be done/try and find shorter springs.
  10. May 4, 2009 at 8:46 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The cheapest approach is a 3/4 drop using the ball joint flip and blocks.
  11. May 5, 2009 at 12:56 AM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    Long Beach, CA
    04 Double Cab PreRunner SR5 TRD
    Blocks for the rear and drop spindels in the front. DO NOT CUT YOUR COILS the ride quailty is crapy. Ive been in the mini truckin scene for years now, thats your best bet.
  12. May 5, 2009 at 3:01 AM
    VooDooTrip
    VooDooTrip Defector
    Gilbert, AZ
    01' BSP S/C S-Runner
    S/C, URD fuel Upgrade, 2.2 Pulley, URD crank pulley, Truetrax locker, custom exhaust, plx, scangauge, D/P mod, amsoil drop in, 18x9.5 stern hyperblacks, ACA projectors, Grillcraft blackmesh, Performance Products valance, R/C Tails, B&M Short shifter, QA1 Coilovers all the way around, upgraded strut rod bars with heim joints, poly bushings everywhere lol, 1st model Streetacos bolt on four link!
    Balljoint flip and blocks x 2. pm beefedtaco and he can help you out with the hardware for the drop and also blocks (steel) that are of the best quality.
