Bad coil pack(s)? Please help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by m1kroe, Jun 17, 2009.
  1. Jun 17, 2009 at 10:14 PM
    m1kroe
    m1kroe [OP] Member
    Tennessee
    2000 Toyota Tacoma TRD V6
    I drive a 2000 Toyota Tacoma V6 TRD. 72000 miles. Have been trouble shooting this problem for about a year. Truck sounds great and drives well when first cranked after sitting for a few hours. Once the engine is heated up, starts to make a "Clicking" sound while accelerating. Also, while idle-ing, the engine sounds like its trying to stay alive, but will only do this after is has been driven a while. Took it to the mechanics and they said the clicking sound was "pre-detonation". I've changed both O2 sensors, new plugs and wires, cleaned the MAF sensor. Should my next step be to troubleshoot the coilpacks? Any information would help. I really want to get my truck running good again. Thanks!
  2. Jun 18, 2009 at 1:32 AM
    offroadTRD
    offroadTRD Well-Known Member
    Dinwiddie County, Virginia
    2000 Tacoma V6 SR5 4x4 TRD- Fabtech
    Fabtech 3" adjustable coil-over system, Alcan 8-leaf spring pack, Fabtech 3" body lift.
    don't be offended by this statement but...... have you checked your oil??? it sounds like you are low on oil actually. The oil is thick (when it has sat for awhile) and thins while you are driving and the crankcase is hot. if your oil is fine, I would start researching valve trouble. I don't know. Maybe this helped.
  3. Jun 18, 2009 at 1:53 AM
    m1kroe
    m1kroe [OP] Member
    Tennessee
    Just had the oil changed so that shouldn't be the problem.
  4. Jun 18, 2009 at 7:06 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    m1kroe,
    I'm confused,your mechanic said it was pre-detonation but did not give you the exact cause.....what the hell gave him that diagnosis?? If it was on a scope or computer..it showed where....why not tell you instead of letting you chase tail and $$$.....
    Sorry to "rant" BUT I'm old school and todays "Parts changers" get under my skin...
    Snoope back quiet
  5. Jun 18, 2009 at 7:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Exhaust leak, or even a vacuum leak??
  6. Jun 18, 2009 at 7:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    have you thought about maybe cleaning your iac valve?
  7. Jun 18, 2009 at 7:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good call!
  8. Jun 18, 2009 at 9:06 PM
    m1kroe
    m1kroe [OP] Member
    Tennessee
    Thanks for all your replies. The diagnosis on the "pre-detonation" was supposedly the spark plugs. But like I said, Ive changed those. They checked for vacuum leaks and said there were none. As for cleaning my IAC Valve, i have no clue what that is. Im sorry, im not very mechanic literate. I noticed tonight comming home that there was a bit of white smoke from my tail pipe? Dunno if that makes a difference or not.
  9. Jun 18, 2009 at 9:09 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    have you seafoamed?
  10. Jun 19, 2009 at 12:17 AM
    m1kroe
    m1kroe [OP] Member
    Tennessee
    No, have not ran any seafoam through it yet. I have ran numerous bottles of injector cleaner through it though. :)
  11. Jun 19, 2009 at 6:33 AM
    EMR
    EMR Well-Known Member
    So Cal.
    2012 Tx Pro
    I know white smoke means you're burning coolant. Can range anywhere from bad gasket(most likely) to cracked heads/block.
  12. Jun 20, 2009 at 10:12 PM
    m1kroe
    m1kroe [OP] Member
    Tennessee
    Ok so I broke down and took the Taco too the Toyota dealership today. 4 hours and 300 bucks got me this information:
    They ran compression tests on the engine and #3 Cylinder had less than 50psi. All the others were fine (i think the man said they were at like 235psi or something). My waterpump was leaking. Engine coolant level was not staying at the correct level so he said that was from the water pump leaking. As for the low psi cylinder...blown head gasket or burnt valve? Should I put some oil into that cylinder and do a compression test to see if it goes up or down? Any ideas? I really dont wanna spend a few thousand dollars at the dealer to fix this. Would really like to do it myself. Love this truck and would really hate to get rid of it.
  13. Jun 21, 2009 at 1:06 PM
    snoope
    Quick question????
    I am hoping the "Tech" checked BUT does your truck have a recall on the "Defect Headgaskets"????..Not sure what years the V-6's had this BUT it did save my sons A$$ and MY WALLET......he purchased his 4 -runner used and not a week later it created white smoke,the dealer ate the labor and all parts except the new waterpump and 1/2 the coolant...
    That might help take the "sting" out of that bad cylinder.......
    Snoope back quiet
  14. Jun 21, 2009 at 1:38 PM
    Mootsman
    Mootsman Active Member
    Gunnison, Colorado
    02 Tacoma SR5
    3" Fabtech Lift
    I didn't know there were any recall on defective head gaskets for the 3.4 V6. How would one go about finding more information on that?
  15. Jun 21, 2009 at 2:22 PM
    jrws6
    jrws6 Well-Known Member
    Jason
    Western North Carolina
    07, Dodge Ram 35004x4 Cummins Turbo Diesel 6M
    No that white smoke is oil going past the wore out rings/ head gasket and into your exhaust from that bad cylinder with 50psi.
  16. Jun 21, 2009 at 4:05 PM
    EMR
    So Cal.
    2012 Tx Pro
    I thought oil was blueish/dark smoke?
  17. Jun 21, 2009 at 4:30 PM
    EMR
    So Cal.
    2012 Tx Pro
    Check out this bit of info I found on diagnosing the problem; could be helpful if you have an air compressor:
