turn signal problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by trailinTaco, Aug 24, 2009.
  1. Aug 24, 2009 at 7:22 PM
    trailinTaco
    trailinTaco [OP] Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    My left turn signal comes on whenever i press on the brake. And it just goes on solid and when i let off the brake its works normal again. Anyone have any ideas or have had this problem?
  2. Aug 24, 2009 at 7:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Check the tail light wires for a broken grond, or bad wires.
  3. Aug 24, 2009 at 7:29 PM
    98tacoma27
    Ben
    Not Beech Creek
    Is it just the front or the rear? IS it just inside the truck (dash lights) or both (outside and and in)?
  4. Aug 24, 2009 at 7:32 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yeah, it sounds like a broken or frayed wire. Those systems are not connected electrically.
  5. Aug 24, 2009 at 7:32 PM
    trailinTaco
    Bel Air, MD
    it goes on in the dash and both front and rear turn signals outside the truck light up too.
  6. Aug 24, 2009 at 9:05 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Bad ground from trailer hitch maybe.
  7. Aug 24, 2009 at 9:32 PM
    drifter379
    drifter379 CenTex Honky
    Texas
    06 Tacoma SR5 Prerunner
    Secondary Air filter mod,Removed running boards,AFE Pro dry filter,sirius satelite radio,relocated horns,sockmonkey decal,EZ change drain plug,color matched grille,grille craft mx, BHLM, Fog light mod, Hellas behind the grille
  8. Aug 24, 2009 at 10:12 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    You have a bulb out, probably the brakelight
  9. Aug 24, 2009 at 10:33 PM
    VixTacom
    VixTacom SYC TACO
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    LED's and Neon Glow inside, Blacked out front end, 4X4 with Locking Diff, 5spd Manual, TRD package, CB Radio, Gray Wire Mod, Thrush exhaust system, Tinted marker lights, tailights, interior lights
    nah, if it were a brake light it wouldn't mess with the turn signal. i had a rear tail light bulb out in my 99 taco nd the turn signals worked just fine
  10. Aug 25, 2009 at 8:34 AM
    96.YOTA
    96.YOTA New Member
    CALIFORNIA
    1996 taco
    7" lift on 33" tires
    i had that happen to me.. it was a brake light bulb that blew out and was grounding out on it self..
  11. Aug 25, 2009 at 3:40 PM
    trailinTaco
    Bel Air, MD
    ok ive taken a another look at the problem. when i have the brake depressed and i disconnect the tail lights and front turn signals the turn signal on the dash is still on so the issue wouldnt be outside the truck or that light would go out when i unplug it. so it must be under the dash. possibly between the flasher relay or the brake switch?
  12. Mar 28, 2010 at 7:18 AM
    WashburnTaco
    WashburnTaco New Member
    Tacoma 4wd
    i currently have the exact same problem. were you able to figure out what the problem was?
  13. Mar 28, 2010 at 7:24 AM
    TaComatoseSR5
    TaComatoseSR5 Mud Junkie
    Stephen
    Tampa, FL
    White 05' SR5 Access Cab 3" lift
    3" Toytec lift (coils and aal), 285/75/16 terra grapplers, HID conversions,led taillights, grillcraft grill, on board air with air horn
    i had a very similar problem my turn signal arrows would light up when I hit the brake. It turned out to be an aftermarket trailer light wiring I disconnected the little box behind the taillight and problem solved.
  14. Mar 28, 2010 at 6:31 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    i have this problem every so often also. Mine turned out to be a corroded brake light socket in the tail light. Last time it happened was in Jan, and its been good ever since.
