Spacers or sway bar or coils...
Discussion in '1st Gen. Tacomas (1995-2004)' started by tyaker, Sep 23, 2009.
  1. Sep 23, 2009 at 10:35 PM
    tyaker
    tyaker [OP] Well-Known Member
    Southern Oregon
    '11 4x4 DCLB TRD Sport
    Leveled, Dakar HD rear leafs, Ride-Rites
    Hey, I've gotta get something done soon, and having started school, there isn't much dough for it.
    Loading up all the rafting gear in the Taco and cruising to Utah, the whole thing's swaying SCARY. I put Alcan 5 leafs on in back, giving it about 1-2 inches lift, but still not stiff enough under the load.
    What's gonna get me the biggest bang-for-buck factor? Stiffen the fronts with spacers (which will level the lift), work out a sway bar for the rear, an air ride system (much later...$$$), or start workin' on a whole new beefy rear setup?:confused::confused::confused:
    Thanks for any help...
  2. Sep 23, 2009 at 11:30 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Your alcans are gaining flex while losing load capacity.
    if you wheel a good bit, dont get spacers. go with ome 881s coils and 5100s up front. 5100s in the back with your alcans should be a good setup.
  3. Sep 24, 2009 at 4:25 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Whatta ya mean by ...swaying scary?
    Did you ever get an allignment done after the rear lift was installed?
    I honestly don't think coils up front will help but it's cheap enough to get it done and try it.
    After you get everything done - I'd HIGHLY recommend an allignment. That's probably most of your problem.
  4. Sep 24, 2009 at 4:29 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    i dunno...youd be surprised how much a stiffer set of coils will do
    my truck doesnt have any sway bars and has 675lb coils on the front and it handles better than it did stock...i can actually take corners faster now
    however...for the OP...those alcan leafs probably are hurting you more than helping you in this case...
  5. Sep 24, 2009 at 10:05 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    Im replacing my stock front that had spacers on them for a set of coilovers in about a week. if your interested i can send you those for real cheap.
  6. Sep 24, 2009 at 10:54 AM
    tyaker
    Southern Oregon
    Pittim: I don't really wheel at all... It's my daily driver and work truck, just loading anything over 500lbs feels too heavy for it. I'd love to do an OME front end, just not enough cash to do it proper. Got stock bilstiens on the back end with the alcans.
    Janster: when on the freeway above 55 with a load, any decent bump causes the chassis to start swinging back and forth, and I gotta correct it by twitching the wheel one way or the other. I did get an alignment done right after I put on the alcans about three years ago. Don't know why it seems to have gotten worse now...:confused:
  7. Sep 24, 2009 at 11:21 AM
    Janster
    Jandy
    Lancaster, PA
    Bump Steer eh?
    Start inspecting your steering components. I know a lot of guys (including myself when I owned my 96) replaced steering rack bushings because of sloppy steering. If you jack up the front end and grab the wheel by hand and try to move it in & out, back & forth, etc. Even have someone turn the steering wheel. Take note to all components...for looseness, wobbles, etc. If you ever notice the entire steering rack moving....then your rack bushings are probably shot. The rack itself shouldn't move.
    You said you have 3" of lift in the rear but no lift in the front? So, does your truck sit nose down (with a pretty good rake)?
  8. Sep 24, 2009 at 2:47 PM
    tyaker
    Southern Oregon
    I'm no expert, but it doesn't feel like a steering issue... Just too soft a ride under a load.
    Yeah, the back end is up a little, but nowhere near 3 inches. more like 1.5". I'll try and post a pic soon. Along those lines, I may be able to get my hands on some 3 inch spacers. With my old/soft (stock) coils on the front, would it even it out? I don't wanna be starin at the sky...:D
  9. Sep 24, 2009 at 3:06 PM
    Janster
    Jandy
    Lancaster, PA
    It could be anything. Steering & allignment often go hand-in-hand. If something is wrong with your steering, then sometimes the allignment can be *out* causing strange problems. Hitting a bump on the road at that speed can setup and occilation affect (hard to explain) to cause the truck to drive funny. That's why I mentioned to check your steering components.
    The fact that you had it alligned 3 years ago and you said this condition got worse....makes me believe you have a mechanical issue.
    Putting stiffer coils in might help, but that can often hide a mechanical issue.
  10. Sep 24, 2009 at 4:05 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    x3.....those leaf springs you have are for lift and rear articulation. For a stiffer set up, I think an AAL (add-a-leaf) would work better.
  11. Sep 24, 2009 at 11:22 PM
    tyaker
    Southern Oregon
    Sorry if the image is big, but I hope this gives you an idea what I'm trying to level off the front end to.
    I see your point with the mech issue, I will be checking out the steering stuff. I did get a new rack and pinion a couple years back, that's when the alignment was done. maybe something else went bad under there.
  12. Sep 25, 2009 at 6:49 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    Long Beach, CA
    04 Double Cab PreRunner SR5 TRD
    I like my 3" coil spacers but i want coilovers
