v6 exhaust an upgrade on 4 cyl as in catback?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tmolina, Jan 5, 2010.
  1. Jan 5, 2010 at 1:18 PM
    tmolina
    tmolina [OP] Well-Known Member
    Thomas
    AZ
    '02 Tacoma dbl cab Prerunner
    2 inch lift with SAW's on front, AAL on rear
    Does a v6 exhaust have bigger diameter tubing than 4 cylinders? If so can it be used for performance gains similar to a catback system with mandrel bent tubing?
  2. Jan 5, 2010 at 1:23 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I'm running headers and a custom 2.5" cat back dump exhaust on my 2.4L. It pretty responsive and sounds really clean. No backfires or that gurgle sound.
  3. Jan 5, 2010 at 3:03 PM
    tmolina
    Thomas
    AZ
    What i am asking is can the v-6(3.4l) exhaust be used on the 2.7l or 2.4l to improve performance?
  4. Jan 5, 2010 at 3:08 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Cat backs in general aren't going to give you any kind of noticeable performance gain so I doubt this would make any difference.
  5. Jan 5, 2010 at 7:30 PM
    MadTaco461
    CA
    Kinda stock
    It will be less of a headache to do a custom muffler than muffler swap. I doubt the exhaust from the v6 will bolt up to the 4 cylinder model. V6 has a y- pipe and different placement of the cats. Performance wise it isn't worth your time. If you want some cheap noticeable power, have a flowmaster/magnaflow welded in.
