Wheel spacers with 2nd Gen TRD wheels on 1st Gen Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by jrad012x, Feb 26, 2010.
  1. Feb 26, 2010 at 6:23 PM
    jrad012x
    jrad012x [OP] New Member
    I have a 2004 Prerunner with a leveling kit and recently purchased a set of 16" TRD wheels from a 2nd Gen Tacoma with P265/75/R16 tires from another member on here. I have been reading that the offset of the 2nd gen wheels is about 5.5"-5" vs. 1st gen of 4.5"-4" which means my wheels will end up moving inward slightly.
    I would like to correct this and possible add more width to my setup. My question is, since I am using 2nd gen TRD wheels, should I use hub centric spacers or stick with the lug centric?
    Thanks for any help,
    Jason
  2. Feb 26, 2010 at 6:28 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    if u go with spidertrax, their newer gen spacers are supposed to be both hub and lug centric so you are covered either way...
  3. Feb 26, 2010 at 6:37 PM
    pdxwhiteout
    pdxwhiteout monster taco in the snow
    coty
    pdx
    monster tacoma
    3-inch body lift, 6-inch fabtech lift, 17-inch procomp black alloys wrapped in bfg 37s. trd v-6.
    x2 post some pics when your done. bet that will look nice.
  4. Jan 7, 2013 at 6:38 PM
    Tonto27
    Tonto27 We came, we saw, we kicked its ass!
    Joey
    Denver, CO
    2004 double cab
    A bumper here, some tires there..... you know, stuff.
    I'm running the same wheels on my 1st gen with spidertrax. Works perfectly.
  5. Jan 7, 2013 at 6:58 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    I did the exact same thing...'09 wheels on an '02....;)
    .75":cool: borla spacers on front only....
    1st pic is with my original alloys and pic 2 is the '09s..
  6. Nov 18, 2014 at 7:18 PM
    alumaman
    alumaman Well-Known Member
    Yukon
    95 Tacoma
    Header, cold air intake 2" body lift
    I've got a 2" lift on my '95 and have found some 16" alloy wheels from an '06 for 400.00 and maybe spacers. I called the dealer to see if they would fit and he say's I will need smaller lugs than the ones that are on my 95. The spacers look like the solution and I will be getting some new rims soon, my original ones are in rough shape and I want to replace them.
