Weird Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by saweetlou, Mar 28, 2010.
  1. Mar 28, 2010 at 5:11 AM
    saweetlou
    saweetlou [OP] Well-Known Member
    Guelph Ontario
    TRD Dbl cab long bed
    3in spacer
    I took my heater control out to change the lights that had burned out and now that I have it back together the only thing that works is the fan, the heat seems to be stuck at halfway and the defrost controls are stuck on one position no matter where the dial is, also the AC doesnt light up either. Is that strange or what, I believe there were only 2 plugs back there, I hope I didnt fry it.
  2. Mar 28, 2010 at 8:31 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Clues, please ... What year Tacoma?
  3. Mar 28, 2010 at 9:05 AM
    saweetlou
    Guelph Ontario
    3in spacer
    02 Tacoma TRD
  4. Mar 28, 2010 at 9:57 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    The fan controls are powered off a different fuse than the A/C main control unit. This suggests you may have blown the 10A A/C fuse (fuse box in the engine bay). If that fuse were blown and the A/C control unit lost power, it might explain the odd behavior.
    Are the HVAC panel illumination lights working? Do all the other dash illumination lamps work?
  5. Mar 28, 2010 at 11:01 AM
    saweetlou
    Guelph Ontario
    3in spacer
    Yes the lights are working, I will check the fuse, Thanks
  6. Mar 29, 2010 at 5:02 AM
    saweetlou
    Guelph Ontario
    3in spacer
    Well I figured out the problem, turns out I didnt have the plug all the way in on the cluster. Problem solved.
    Thanks Guys
