Camburg Coilover Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by OlyTacoma173, Mar 30, 2010.
  1. Mar 30, 2010 at 5:56 AM
    OlyTacoma173
    OlyTacoma173 [OP] Well-Known Member
    Olympia, WA
    2004 Xtra Cab TRD 4x4
    LineX Spray-in bedliner, deckplate mod, K&N High-flow filter, Camburg Coilovers and UCAs, Alcan leaf-pack, Elite plate bumper
    I have Camburgs coilovers installed on my truck and recently changed out my stock tires for 285/75/16 BFG All-Terrains. I am getting a little bit of rubbing in turns on the rear of the fender well. I trimmed out some of the plastic liner which helped, but the tires are still touching a little bit of metal in turns. I know that I can adjust my coilovers to give me a little more height and added clearance for the tires but I'm not sure how much of the thread should be exposed on the coilovers. For those of you with Camburgs on your 1st Gen 4x4's, how much thread do you have showing? Thanks!
  2. Mar 30, 2010 at 7:23 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    in your case what you need to be more concerned with are your CV angles. as long as the CV is still at a decent angle and the fins on the boot are not touching eachother you'll be good. i had my icons adjusted to about 2.5" lift (dont rememebr how much thread showing) and i still rubber my tire's (same size as you with 4.5" basckspace wheels) on the frame.
  3. Mar 30, 2010 at 11:09 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Some people said as long as you can get a paper between the fins, you are fine.
  4. Mar 30, 2010 at 2:58 PM
    OlyTacoma173
    Olympia, WA
    Thanks guys. Guess I'll just crank them up as far as they'll let me without putting any undue stress on the CV boots and joints. Appreciate your help!
  5. Mar 30, 2010 at 4:03 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    also, if on stock wheels, you need less backspace...
    on 285s, your best bet is 4"
    you can also have your casters set forward 1.5 to 2 degrees
  6. Mar 30, 2010 at 4:32 PM
    OlyTacoma173
    Olympia, WA
    Mikes, thanks for your reply. For the backspacing, I read that the stock alloys have 4.5" of backspace. Will wheel spacers correct the backspace issue and if so, which would you recommend? I've read that Spidertrax are pretty much the only way to go with spacers but only see them available in 1.25".
  7. Mar 30, 2010 at 8:41 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    for the life of me, i cant remember the other company... there is a company that makes spacers for tacomas in various sizes from 3/4" to 2"
  8. Mar 31, 2010 at 7:53 AM
    sirsaechao
    Tim
    CA
    All Pro makes up to 2.0" Mike.
  9. Mar 31, 2010 at 8:01 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    i dont think the OP is looking for that much, prob more like a 1" spacer. i could be wrong though, i'm still working on my mind reading skills
  10. Mar 31, 2010 at 1:23 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    hold on i think everyone forgot about the pinch weld mod
    OP...hammer the pinch weld flat (thats the exposed metal underneath the plastic liner)
    thats where youre talking about right?
  11. Mar 31, 2010 at 1:26 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    x2... even after that, he may still be rubbing on the frame too...
  12. Mar 31, 2010 at 1:30 PM
    JimBeam
    JB
    2015 Tundra
    more than likely...i still get some rub and the Ivans are backspaced more (or less i dunno but they stick out more) than stock wheels
  13. Mar 31, 2010 at 1:53 PM
    OlyTacoma173
    Olympia, WA
    Tiger, yeah, that's exactly where I am talking about. I'll let you all know how it works out once I'm able to do it. Broke my leg a few days ago so mods are on hold for a while.
  14. Mar 31, 2010 at 1:57 PM
    JimBeam
    JB
    2015 Tundra
    now that youve trimmed the plastic...its easy to do
    you can remove the tire and use a BFH...but i chose to leave the tire in place...i used a regular sized hammer and got it pretty flat...then all the paint i chipped in the process i sprayed with flat black rattle can
