Engine oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by PnoyBOS5, May 13, 2010.
  1. May 13, 2010 at 9:07 PM
    PnoyBOS5
    PnoyBOS5 [OP] Well-Known Member
    kevin
    CA
    2013 PRERUNNER
    Maxtrac 4'' Spindes -Bilsteins 5100 @ 1.75" - All Pro Expo Leaf Pack - Extended Rear Shocks - PC 5001 wheels - 285/70/17 Goodyear Duratracs - Debadged -Red emblem - AFE Pro Dry-S Filter
    How much does my 97' tacoma 4 clynder take?
    I heard 4 quarts?
    i recently inhereited it and it has no manual and i do my own oil changes just not for this vehicle yet!
  2. May 14, 2010 at 1:50 PM
    PnoyBOS5
    kevin
    CA
    2013 PRERUNNER
  3. May 14, 2010 at 2:18 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Bro It should be between 4-5 qts, I don't know for sure. I did a quick search here and on google and couldn't find anything. Some guys on one forum said they had to put in 5.5 qts for their 4 cylinder.
    I would recommend buying 5 qts, and put 4 qts in and check the level on the dipstick. If the level is between the two lines you will be fine. But after that I would recommend running the truck to normal running temp., and then turn off the motor for 4-5min and let the oil drain back into the pan. Then check the level again, and add if needed to the top level. Also make sure your truck is parked on level ground, like a garage.
    Hopefully someone can chime in and give the correct amount, but if not that will do just fine, or try doing a more detailed search on google.
  4. May 14, 2010 at 2:30 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    5 quarts with filter for 4wd....5.8 for 2wd
